Hot Rods New Power for the Money Hole in the Garage
Discussion in 'The Hokey Ass Message Board' started by AKGrouch, Apr 14, 2017.
  1. AKGrouch
    AKGrouch
    Well, the 350 tri-power want tu. #8 plug would oil foul out in 40 miles with #7 trying catch up. I.E. Major TLC and a rebuild needed. Was gonna bite the bullet and rebuild until a buddy offered a 383 short block w/o a cam and only about 50 miles on it for almost a song!!!! Had a SCAT crank and rods, TRW pistons, 4 bolt mains, ARP throughout, and balanced to boot! Can you spell "break your arm getting the checkbook out?" Took the L79 cam out of the 350 and stuck it in the 383 with some performer rpm heads. Unfortunately, the wonderful Offy intake will not fit the ports in the heads so my wonderful 6 pack won't work. Now I'm waiting on an Edelbrock dual quad setup to get here. but here's what it looks like so far. Getting excited to drive it and see what it might turn in the 1/4.
    20170329_164748.jpg 20170331_110332.jpg 20170414_160329.jpg 20170414_160307.jpg
  2. Jalopy Joker
    Jalopy Joker
    why run a used cam/lifters? new motor sounds too good to risk anything on
  3. The ports don't fit?
    Bandit Billy and loudbang like this.
  4. mcsfabrication
    mcsfabrication
    I would always run 2 x 4's rather than tri-power. Tri-power for customs, 2 x 4's for hot rods.
    swade41, mad mikey and loudbang like this.
  5. hum a few bars.......
    ????? ports don't match ?????? die grinder......
    Bandit Billy likes this.
  6. AKGrouch
    AKGrouch
    The Comp Cam and lifters have less than 500 miles on them, i.e. basically new.....no trace of scuffing or wear whatsoever and we made sure each lifter went back on the correct lobe.
    coast40 and loudbang like this.
  7. AKGrouch
    AKGrouch
    Nope. The intake ports on the heads measure a hair over 2" and the ports on the Offenhauser intake measure 1.7? Slightly diff widths too. Even Edelbrock tech support said no joy on the Offy intake.
  8. AKGrouch
    AKGrouch
    Not if there isn't enough room in the casting to open up the intake to what is necessary..
  9. Use the intake. You choke it a bit. It will have better bottom end.
  10. AKGrouch
    AKGrouch
    Then I'll have a reversed funnel effect and choked down more than a little bit Chopped 51. The engine cam and heads are designed to respond best between 1900-6200 rpm. My cruise rpm will be about 2300 with the 4.11 gears.
  11. AKGrouch
    AKGrouch
    The new engine coming together slowly. Got the intake, carbs. distributor and radiator installed. Also got the new battery box and 15 gal fuel tank in it now Here are a few update pics.
    20170518_160748.jpg 20170525_161323.jpg 20170526_132916.jpg 20170526_132951.jpg
    swade41, kiwijeff, mad mikey and 2 others like this.
  12. AKGrouch
    AKGrouch
    Finally got the coupe back on the road again. Geez that stroker is torquey.....goes like stink too. Almost scared myself last night as I wasn't expecting the quick response....makes the 350 and deuces seem like a VW!!! Should have done this a long time ago. The Edelbrock heads and dual quads work flawlessly....no hesitation, stumble, or pause of any type.....just awesome head snapping response. Merging onto the on ramp, crack the secondaries and the torque shoves you back in the seat. Haven't had the nerve to try WOT yet.. Think I should get more used to it first. Life is grand!! Here's a pic of the final engine.
    swade41, kiwijeff, mad mikey and 3 others like this.
  13. big duece
    big duece
    from kansas
    If there is only 50 miles on it, and the cam is removed sounds as if a cam lobe was wiped out. Might be good to make sure it does not have any metal in the oil galleries or you will be taking it apart again.
  14. AKGrouch
    AKGrouch
    Cam and lobes were perfect and all lifters went back on same lobe. Regardless we already plan to change the oil and cut and spread the filter next week. Can never have too much caution with a fresh engine. Thanks for the reminder.
    big duece likes this.
  15. partsdawg
    partsdawg
    from Minnesota
    Sounds like a winner!
  16. Mr48chev
    As you take care to put the lifters back with the same lobe they were running on it works fine. Mix them up and you are in for trouble.
    AKGrouch likes this.
  17. lippy
    lippy
    from Ks
    I know he would have loved to use the 3 deuce manifold, but I bet the problems were not on the inside of the ports matching but on the outside. Lippy
  18. jetnow1
    jetnow1
    from CT
    1. A-D Truckers
    dual 4's, 411 gears and 383. 15 gallon tank. Looks like frequent fuel stops, but should be a lot of fun.
  19. Big midrange torque in a light car equals fun!
    AKGrouch and mad mikey like this.
  20. Looks good, drive the wheels off it!:D
  21. Engine man
    Engine man
    from Wisconsin
    I prefer to call them pre-tested.
  22. Engine man
    Engine man
    from Wisconsin
    I think he was speculating that the engine you got that didn't have a cam, had a cam problem before you got it.
    AKGrouch and big duece like this.
  23. AKGrouch
    AKGrouch
    It was both inside and outside. New and modern tech vs old tech. The dual quad air gap intake matches inside and outside.
  24. AKGrouch
    AKGrouch
    Absolutely!!
  25. AKGrouch
    AKGrouch
    Could be. Truth is money got short with all that we were doing to the car and a roller cam was too spendy. Had the L79 flat tappet and lifters with only 500 miles on it in pristine condition, why not use it? :)
  26. sololobo
    sololobo
    sweet mill bro, wish it was going in my truck!! enjoy
