Projects 1956 Customline
Discussion in 'Traditional Customs' started by Auslander, May 10, 2017.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
    These will clear with zero alterations in a 1952-59 with a 302/5.0 swap https://www.jalopyjournal.com/forum/threads/another-sbf-header-for-53-woohoo.1058469/ Or the HEDMAN 88400 https://www.jalopyjournal.com/forum/media/albums/hedman-88400.45641/
    loudbang and Auslander like this.
  2. Auslander
    Auslander
    from Austin, TX
  3. Auslander
    Auslander
    from Austin, TX
    So another oddball question. Cheap aftermarket temp gauge is reading 210, while a temp probe and an infrared thermometer say water temp is more like 160. Not a big deal, as as long as it always reads the same I'm good, except that's almost pegging the gauge. Anyone know where to start with a resistor to get a closer reading? I'm not too concerned about exact reading, just would like to back the gauge off a bit.
  4. Auslander
    Auslander
    from Austin, TX
    https://www.jalopyjournal.com/forum/threads/resistor-for-temp-gauge.660639/
    Found this thread, I like the thought of an adjustable variable resistor. I'm still open for suggestions, but I'll try a few things and share my results.
  5. Auslander
    Auslander
    from Austin, TX
    So as to the sun visor brackets, I was able to find some serviceable brackets from a 1958. Not an exact match, but with a little persuasion and bending the arms a little, they look like they will work fine. Thanks to bobss396 for the idea!
  6. Auslander
    Auslander
    from Austin, TX
    Now for a break, out to lunch. Ran her hard in 100ºF and she was a champ, great oil pressure, good temp, everything seems solid, and she sure seems happier...
  7. loudbang
    Get your tires balanced at a place that has stick on weights on the back side only. The hammer on weight really jumps out at you. But the rest of the car is AWESOME. :cool:
    Knghtcadi, tomkelly88 and Auslander like this.
  8. mcsfabrication
    mcsfabrication
  9. Auslander
    Auslander
    from Austin, TX
    So I got the Temp gauge displaying properly. Bought some Bourns variable resistors ended up using a 100Ω and dialing it in slightly. I call that close enough for a hot rod, and it's nice not to see the gauge pegged. Oh and I tidied up the resistor, that was the mock up to get it dialed in, but this way you can see it :)
  10. DIYGUY
    DIYGUY
    from West, TX
    Pretty dang clever! Good job.
  11. verde742
    verde742
    I REALLY like yer Ford,
    In a group, I would head right for it,,,
    cause it shore looks good in pictures !!!!
  12. Auslander
    Auslander
    from Austin, TX
    So added a HEI dizzy for simplicity's sake (and further cleaned up the firewall). I know the issues and problems, and pros and cons; for example I know I need to get a spare control module and throw it in the glove box. I dislike the size, but there is something about retrofitting an GM product onto a Ford :) and you can't beat the function and simplicity. Need to clean up the wires...
    OahuEli, loudbang and Austinrod like this.
  13. Auslander
    Auslander
    from Austin, TX
    So in preparation for AC, I need to add a better radiator. I thought I had it all figured out. I got an aftermarket radiator, had the outlet swapped to the passenger side (to eliminate the crossover lower radiator hose). It will be a brilliant clean installation...
    So, I go to install it and the mounting brackets are on backwards (facing back instead of forward). And the radiator is too wide to fit any other way. Even if I flip the brackets the right way the radiator is too wide to fit closer forward. I could cut up all the front sheet metal to make it fit, but that seems way too drastic, I'd rather get a smaller radiator and fab up brackets.
    So assuming all that, the problem is twofold: First, it puts the radiator too close to the engine and fan in my current configuration. Second, it creates a weird gap in the surround/latch. This might not be too bad once I add the AC condenser and dryer, but seems odd to me now.
    Upon reviewing ALL the 1956 aftermarket radiators I can find, they all are that way (backwards mounting brackets and too wide). So a couple of questions for the group:
    1. Do I just scrap all this nonsense and re-core the existing? My worry here is the AC in hot TX summers. I realize I could have a new one made up from scratch or something, but first I'd like to see if I can't sort what I have out.
    2. Do I need the U shaped radiator support? It seems I could remove that, and mount the radiator a little farther forward, that might be the optimum solution. I could also either grind down the existing support, or weld up a new one if the view is that it's a necessary item. Of course, nothing fixes that gap all the way. Really not sure how I feel about that.
    3. Anyone have a better idea? :) What are others running? If I can get something that works right, I guess I'm open...
    Austinrod likes this.
  14. It's been a little while since doing mine but I seem to recall the yolk is turned around and aluminum blocks are used as spacers to push the radiator all the way forward. I found some pictures from the install that might help.
  15. DIYGUY
    DIYGUY
    from West, TX
    So are you saying the new radiator is not made like the original? Doesn't bolt right on?
    Auslander likes this.
  16. Auslander
    Auslander
    from Austin, TX
    Dos Cincos, thank you! This is exactly what I was looking for!
  17. Auslander
    Auslander
    from Austin, TX
    Correct. It looks like most of the aftermarket radiators look correct, but the "ears" on the mounting brackets face the wrong way, and most seem too wide to easily fit in the radiator support and no way will fit in the front apron without some serious chopping. In measuring my new aftermarket radiator, it is 23" wide, vs the 19" of the original, and as I said the brackets are backwards. Kinda stupefied that all the aftermarkets are wrong like this. I'm thinking they scaled down, or mislabeled a F100 radiator then all copied each other?
  18. I should have mentioned that my car was originally an I6 car so it had a different front apron than the V8 cars.
  19. Auslander
    Auslander
    from Austin, TX
    Just went out and checked, looks like it should still work a treat. I'll need to move the horns back a bit to clear the mounting brackets, but my biggest issue was going to be the huge gap, your trick really minimizes that.
    hawksrod and loudbang like this.
  20. DIYGUY
    DIYGUY
    from West, TX
    I'm needing a radiator soon for my 56, now don't know what to get! 64-69 mustang supposed to nearly bolt in, another option.
  21. Auslander
    Auslander
    from Austin, TX
    Wow, I wish I would have looked at those. That looks like a better fit, with one exception, if you're running a Y block, you'll need to either have the outlet swapped to the drivers side, or run a crossover. Since I'm running a 289 and paid not only for a radiator that wont fit, but also the cost to swap the outlet, I feel like hitting myself on the head and saying, "I could have had a V8"... <sigh>
    Mustang radiator 1964-1966, notice the mounting brackets and the size...
  22. loudbang and Auslander like this.
  23. DIYGUY
    DIYGUY
    from West, TX
  24. Auslander
    Auslander
    from Austin, TX
    So, my upholstery guy is a bit backed up. No problem, I've now been able to get started on the AC/heat/defrost and hopefully get all the interior items done before dropping the car off. This is one of the few jobs so far (knock on wood) that hasn't been that bad. But this is just the inside...
  25. JeffB2
    JeffB2
    from Phoenix,AZ
    Before the radiators that were for 54-56's came out recently the guys in the 1952-59 Ford Group used these:http://www.ebay.com/itm/JDN-3-ROWS-...ash=item3f7c209f13:g:Tl4AAOSwq1JZEFfY&vxp=mtr The 6 cyl Mustangs had the lower hose on the drivers side like 1970 and later SBF's. To gain extra radiator clearance you can use the 1966-69 "short" water pump which has the passenger side lower hose. This tread is in our "sticky Faq" that explains things in detail,Scroll to post #5 https://www.jalopyjournal.com/forum/threads/sbf-short-water-pump-pulleys.303600/
  26. DIYGUY
    DIYGUY
    from West, TX
    Thanks Jeff for that explanation, I could not figure out why the Mustang radiators were used when there was an exact replacement available. Now I know the history.
    Auslander and loudbang like this.
  27. Auslander
    Auslander
    from Austin, TX
    Finishing up the heater and AC systems. It's always funny how things that should take 2 hours to complete often take 10 and things that should take 10 often take 2. I pray this all works, there has been a lot of praying and cursing these past few evenings... And as an end result I ended up with a 2 core generic radiator, we'll see what the jury says after a few hot days in 100ºF here in TX; the "1956 Fairlane" radiator was a complete bust; there was no way that could fit in this car with the added condenser...
  28. DIYGUY
    DIYGUY
    from West, TX
    You have made a ton of progress in a short time!
  29. AldeanFan
    AldeanFan
    What a/c setup are you using? Looks perfect for my '54 wagon
  30. Very nice good work..
