Hot Rods What would be a good ballpark guess to rebuild a Model B motor?
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Jun 15, 2017.
  1. rusty rocket
    rusty rocket
    I did a search but didnt come up with any information. I looked at h&h and did not find anything. Just sort of wondering.
  2. atch
    atch
    Somewhere just south of the contents of Fort Knox.
    Sorry I don't have a "real" answer. A friend has his B motor in the machine shop right now. If he smoked he could light cigarettes with $20 bills and he's concerned about the cost.
    b-t-w; love your sedan.
    m&s rodz likes this.
  3. 5window
    5window
  4. Tim: Are you talking about a 4 banger or flathead v8? I rebuilt the '46 truck motor in my '32 pickup in '12. I didn't have to bore it. Rings, bearings, thermal clean the block, gaskets. Lapped the valves at home and still spent $900 on a running motor. So, if you bore, by pistons, rings, bearings, cam, lifters, gaskets, machine work.....???? 3-4 g. Go hog wild and the sky is not the limit.
  5. doliak
    doliak
  6. Call Bert's, (303) 293-3673. I think they sell Model A Motors on an exchange basis. That should give you a good first cut. The A and B motors should be about the same cost. Of course when your block ends up being cracked and you need 4 sleeves the price will go up. This might be a better question for fordbarn.com. My guess would be about $4K before you start adding special equipment. Of course you want to have it balanced and the list goes on.
    Charlie Stephens
  7. rusty rocket
    rusty rocket
    I'm asking about the model B 4 cylinder.
  8. rusty rocket
    rusty rocket
    Hey Trev, You are correct Dean slipped my mind.
  9. oldolds
    oldolds
    Most of my restorer friends tell me that a "normal" 1920's to 30's engine costs a minimum of $1000/cyl. If you are working on something odd it easily doubles. That is for stock rebuilds. All the work on old engines is considered "custom machining" by most machine shops.
  10. 51504bat
    51504bat
    H&H Flatheads quotes prices in their catalogue if I remember correctly.
  11. Hot Rods Ta Hell
    Hot Rods Ta Hell
    At $4000+ for (just) a rebuilt short block, I'd be shopping for an entire Model A recently restored or preferably a stalled restoration (5-8k) where the owner has already rebuilt the drivetrain and possibly chassis. You could sell off the chassis and other stock parts and come away with a clean engine and a solid body (Sedan, Pickup, etc.) to start a Hot Rod project.
    Another angle is to find a Rodder that bought a restored Coupe or Roadster just to get the body and has rolled out the sock/running chassis (hear it run) for sale at a deal to recoup some of his investment.
    INVISIBLEKID, 5window and 302GMC like this.
  12. oldolds
    oldolds
    A Model B motor is not a Model A motor. Close, but if the guy is looking for B motor stuff He has something specific in mind.
  13. Hot Rods Ta Hell
    Hot Rods Ta Hell
    My bad. Still may apply (though harder to find). Makes the restorers cringe, but a lot of guys start with an all stock, sometimes running car or stalled project. Keep the body and pretty much sell off everything else. See it with everything from Model A's through Tri Five Chevy's.
  14. 5280A2
    5280A2
    Check the websites for Durable Performance in Jordan Minnesota and Antique Engine Rebuilders in Skokie Illinois. There is a complete listing for Model A short and long block rebuild pricing using insert bearings that will get you in the ballpark for costs; the Skokie firm is a major supplier of insert bearings and new, forged connecting rods for A and B applications. Expect Model B to cost more due to generally higher costs for parts. If you rebuild with babbit bearings you can also expect to pay more; it's getting hard to find good babbit work in the Midwest so many folks are going with inserts.
  15. 5window
    5window
  16. bondolero
    bondolero
    I advise buying a banger motor and having it done to your liking, albeit expensive by a reputable builder. Especially if you plan on running the heck out of it (see the sport coupe banger build.)
    Cosmetically restored does not translate to your definition of mechanically sound.
    Remember a lot of restored ford owners never plan to take their car to TROG ! :D
  17. No offense to restorers, but would not trust any restorers version of 'rebuilt.'
    RICH B likes this.
  18. GMC BUBBA
    GMC BUBBA
    Rons Machine Shandon Ohio. does a ton of them every year......
  19. winduptoy
    winduptoy
    I would add that it depends on how you want to use it. I have always stated 'Model (A) B Ford, the engine you can spend the most on to go slow'....but I love them and money is a renewable resource.
    I would insert it if you plan to drive it at all. Piranios Antique Automotive Machine http://www.modelaparts.net/
    has parts & machine cost breakdown list.
    Antique Automotive is Skokie Ill makes insert bearings and rods and check his web site.
    If you plan to drive it, North of $4K pretty easy especially if you want a performer
    Stock, not so much
    Larry
    5window likes this.
  20. 5window
    5window
    Cool motors, but for $4K you could pretty much get a turn-key 385HP SBC from Summit. Hard to resist for some.
  21. denis4x4
    denis4x4
    from Colorado
    All well and good, but then you have another belly button car. I'm reluctant to admit how much I've spent on the '31 A engine in my avatar. But it's a non-issue when you get the dyno slip showing 60HP at the rear wheels when the stock engine put out 40HP at the flywheel. Taking my '29 CCPU to Lincoln tomorrow for the Speedster Reunion and looking forward to the dyno run next Saturday. The engine in the CCPU is a B with an original CRAGAR head and was built at Bert's. DSC00006.JPG
    barrnone50 likes this.
  22. 5window
    5window
    Oh, I totally agree, I was just pointing out the options. I appreciate your efforts. It's also possible to build a non-belly button car using a modified "crate" motor. After all, that's essentially what you did-took a stock motor and had it modified. There are just more modified late model SBC's than early Model A's and B's. Not looking for a fight. Have fun at the Reunion.
    H380 likes this.
  23. Fortunateson
    Fortunateson
    Did I sell mine too soon? Professionally re-built, welded and ground crank, four cylinder sleeves, etc. All too standard plus two rebuilt trannies for $2800 about tens years ago. Advertised for two years and nobody want it. Oh well....
  24. bondolero
    bondolero
    Amen, Ive seen mercruiser (old Nova) 4 cylinders with T5's that were mucho cool, easy to repair, and perform unbelievable.
  25. I can relate to your decision. I have a Mercruiser (181 cubic inch) in my AVATAR. I put it in in about 1985. The main factor in the decision is I couldn't (at that time) find anyone I trusted to rebuild a Model B engine. Everyone knew how to work on SBC's and this engine is just half of one. Plenty of power for me for the weight of the car. The nice thing is that it didn't require any irreversible modifications to the car. I may put a Model B engine back with all of the good rebuilders available today.
    Charlie Stephens
  26. manyolcars
    manyolcars
    Which transmission are you using?
  27. I am using a '39 Ford transmission. That is more than adequate for the way I drive the car. The bolt pattern at the back to the engine is the same as a SBC and adapters are available new or used. I am running the '32 rear end. It was really a "bolt together" project (like I planned it). It is sure nice to do a conversion where you don't have a fan clearance problem. If anything my fan is too far from the radiator.
    Charlie Stephens
    timwhit likes this.
  28. rusty rocket
    rusty rocket
    The reason I asked was I need to find something vintage for the project. Its a 22 dodge cowl narrowed 6 inches and a pair of 46 ford front fenders sitting on a T frame. IMG_1782.JPG IMG_1987.JPG I already have a flathead v8 car so I would like to do something a bit different.
  29. Ever think about a big 'ol torquie 6 cylinder?
  30. rusty rocket
    rusty rocket
    I would think about a 40s Ford or Dodge flathead six for sure. I donk care for sixes but I like weird.
