Technical Has anyone put 63 Corvette tail lights on a 33-34 Ford?
Discussion in 'Traditional Hot Rods' started by Early Ironman, Jun 3, 2017.
  1. Early Ironman
    Early Ironman
    I have a set of these tail lights. Will give them to my brother in law for his 33 5 window if he will use them. Just aren't sure how it would look under the trunk lid. Is the angle about the same? We are not close enough to take them over to judge that way.
    So wondered if anyone has done this before. I have not seen it done. But think it might look pretty cool.
  2. BJR
    BJR
    Just say NO!
    LOU WELLS and dylan60 like this.
  3. Jalopy Joker
    Jalopy Joker
    x2
    LOU WELLS and Early Ironman like this.
  4. MAD 034
    MAD 034
    from Washington
    I think it would be a poor choice -- kind of a strange mix.
    LOU WELLS likes this.
  5. I'd vote NO! Ya got better choices. Mostly from the same time period. Original taillights, 37 Ford, 50 Pontiac style, and etc.
  6. Jibs
    Jibs
    "HAS ANYONE PUT 63 CORVETTE TAIL LIGHTS ON A 33-34 FORD?"
    God I hope not.
  7. rush549
    rush549
    from Kansas
    NO!!!
  8. deucendude
    deucendude
    from norcal
    If you do you will have the 2nd ugliest 34 on the planet. There just has to be one worse out there!
  9. xracer40
    xracer40
    They wouldn't work very well, you would have flip them upside down plus they have left-right taper also. Each one of the four taillights is slightly different. There is a left outer and left inner,right inner and right outer. This is a picture of my 40willys with vette taillights. They are mounted with a slight twist to fit the body contours better. The original builders installed them in the 60's so I am not going to change them but there probably was better choices.
    41 coupe and cactus1 like this.
  10. AngleDrive
    AngleDrive
    from Florida
    YUK!!!!
  11. I have to agree with all the previous reply's,there are many more taillights that are proven over & over to look good on 33/34 Fords.
    Remember the Mustang taillights that was popular but thank goodness short lived back in the 70's,the Vette taillights might work well on some cars but not the 33/34 Ford. HRP
    tfeverfred and hounddogjake like this.
  12. 41woodie
    41woodie
    Ya don't paint a mustache on the Mona Lisa
    BJR, LOU WELLS and 54vicky like this.
  13. LOU WELLS
    LOU WELLS
    from IDAHO
    Run the stock 33/34 lights until the plan passes IMHFO....
  14. Could look good on a mid/late 60s build? I say prove everyone wrong...but I like kooky shit.
    kidcampbell71 likes this.
  15. theHIGHLANDER
    theHIGHLANDER
    Never say never again...?
    (images from a google image search)
    The only thing I'd change on this one is the name on the title. Yes, that includes the Vette lights, but look how many other cues to a period exist on it. As a generic use because you can? Maybe not. Here? Best choice IMO. Your results may vary, see your retailer for details, blah, blah, blah...
    Sancho, K13 and LOU WELLS like this.
  16. uncleandy 65
    uncleandy 65
    No, but I put them in my 34 Chevy
  17. Early Ironman
    Early Ironman
    Thanks,
    I was having a hard time visualizing it. Even though we were thinking further apart than these. I am not a fan of them either.
    I took them off of a 78 Jeep CJ5 because they were ugly as sin on that.
    Anyone want some cheap tail lights?
  18. 40Standard
    40Standard
    from Indy
    I would not use them
  19. Harland grunder
    Harland grunder
    L l hope not
  20. don't try any thing different, just do what everybody else does....:rolleyes:
  21. Pete F
    Pete F
    If your building a 60's hot rod fine but if your building a 40/50's hot rod hell no!!
  22. thunderplex
    thunderplex
    I'll go on record as saying, "use 'em but move them in 2s outboard."
    If you like 'em use them. Don't have a narrow vision like some HAMBERS.
    Remember, everything was initially tried by one individual. ...just my $.02
    cactus1 likes this.
  23. upspirate
    upspirate
    I think I've seen a set used in a rolled rear pan that was made at an angle so the lights were positioned correctly.....tucked under ....looked fine
  24. noboD
    noboD
    63?? That's a lot of Corvette tail lights!
    Early Ironman, tb33anda3rd and nochop like this.
  25. nochop
    nochop
    from norcal
    Ha (smart A$$)
    Early Ironman likes this.
  26. Photo shopped.
    And not a 33/34 coupe but close
  27. Close your eyes and envision a pair of sox on a rooster...
