Technical What does this symbol mean
Discussion in 'The Hokey Ass Message Board' started by itsonsucka, May 18, 2017.
  1. itsonsucka
    itsonsucka
    Thanks
  2. itsonsucka
    itsonsucka
    Help if I post pic lol[​IMG]
    Sent from my SM-G925W8 using Tapatalk
    deadbeat likes this.
  3. Not sure about the coil in the circle but the lines in a triangle usually represent a ground.
    Phillips likes this.
  4. steinauge
    steinauge
    from 1960
    If you are talking about the 3 lines they indicate a ground.
    chasey32 likes this.
  5. F1Jim64
    F1Jim64
    Heater element then ground? Block heater maybe?
    Sent from my SM-G920V using Tapatalk
  6. stuart in mn
    stuart in mn
    It's a light bulb.
    39cdan, deadbeat, metlmunchr and 12 others like this.
  7. onetrickpony
    onetrickpony
    from Texas
    The curl in the circle is a light bulb, like Stuart said.
  8. GMBOWTYE
    GMBOWTYE
    from Ames IA
    lite bulb in a circuit. junction of wire. lite bulb &ground
  9. Clearly its a worm wearing a Devo helmet
  10. squirrel
    that's not a helmet, that's an Energy Dome™.
    mgtstumpy, deadbeat, Jet96 and 2 others like this.
  11. jimmy six
    jimmy six
    The rectangle is a joining spot for 2 wires. Like above ^^^^ its a light bulb and I'd guess a dash light..
    Alonzo "Lon" Wilson likes this.
  12. Slopok
    Slopok
    International sign for Transgender!:eek:
  13. flatheadpete
    flatheadpete
    from Burton, MI
    I think it means you should install the hot plate right there.
  14. Mike51Merc
    Mike51Merc
    Yes, it's a light bulb.
    Must be about 20 of them on your schematic.
    oj and 54vicky like this.
  15. AVater
    AVater
    1. Connecticut HAMB'ers
  16. seb fontana
    seb fontana
    from ct
    Good one...:D
    AVater likes this.
  17. Gray Ford
    Gray Ford
    from Illinois
    Only if it has FE power ....
    deadbeat and AVater like this.
  18. Is it a schematic for an accessory boiler and plumbing for a steam engine lost from another thread?
  19. itsonsucka
    itsonsucka
    It is lightbulb or where two wires met and create a light thanks guys
  20. If it's from a Lucas wiring diagram, it's where the smoke comes from.
  21. KRB52
    KRB52
    from Conneticut
    Is that also known as a "short"?
  22. it's the international symbol for "start troubleshooting here"......
  23. Heat food here
  24. Engine man
    Engine man
    from Wisconsin
    Smoke comes from anywhere in a Lucas system.
    Bomb and deadbeat like this.
  25. RMONTY
    RMONTY
    Wow.... Mr. Kerbel my senior year instructor in general electricity class would be proud. I recognized the light bulb symbol immediately. That was 40 yrs ago...damn!
  26. Dang even I knew that! They taught it both years I was a senior.
    King ford and RMONTY like this.
  27. lippy
    lippy
    from Ks
    In Ks it's mandatory to take 6 years of high school. :) I took 8 and still flunked.
    mgtstumpy and Jerrybigbird like this.
  29. Jerrybigbird
    Jerrybigbird
    from Montana
    tb33anda3rd likes this.
  30. butch27
    butch27
    "I've had a vasectamy " ??
