Auctions
1927 ford model T coupe & price drop
Discussion in 'Cars For Sale' started by rat nasty, Apr 27, 2017.
  1. rat nasty
    rat nasty
    City: louisville
    State: Kentucky
    Price: $4500
    1927 Ford model T coupe "Project" currently sitting on a 2x3 box tube chassis thats been Z'd up in the front and the rear all is mostly just tacked and will need to be finished welded. has after market Model A front cross member.
    currently mocked up for a 24 stud flat head & a ford 4 speed trans. (this motor & trans does not go with sale of this car)
    body: very solid still has all the sub rails intact doors open & close with factory hinges & latch with factory mechanisms. stock firewall, has Model A dash, fabbed drop swinging pedals for clutch & brake with new mc, steering is F1 and hooked up the car rolls & steers steering arm will need to be re made this one was used just for mock up? also has cowl door, wind sheild frame but missing top the frame, has deck lid needs new skin, have the section below the trunk lid. 33' ford truck grill, head lights & bar.
    37" front axle, new shackles, bushings, perch pins, juice brakes fr & rear, split wishbones with bungs and heim joints, F1 front shock mounts, F1 steering box & column cut down column, 5 lug 5.5" bolt pattern fr & rear the rear is out of an F1 with spring perches welded to top of axle tube with a model A spring from speedway thats the lower than stock height. rear suspension needs to be finished there is no shock mounts or any type of bars or links fabbed currently was planning a rear set of bones or 4 link?
    as of now the car rolls and steers and looks as pictured photos taken on 4/24/2017 NO TITLE located in Louisville, Ky. will help load for shipping but must be paid & money in acct before shipping! shipping arrangements is up to buyer?
    car comes with a sbc for mock up that needs a rebuild with a empty 350 th case. for $4000.00
    car can also be bought with a 1955-56 dodge super red ram 270ci. turns over but needs rebuild but is complete carb to pan have clutch bell pp to bearing flywheel 3 speed trans all for $5000.00
    The Hemi can be purchased seperately also!
    Reason for selling need to fund another project to build sorry no trades excepted at this time.
    I have posted this ad for my Dad it is his car you can contact him about this by calling him
    @ 502-681-4400 Tony no TEXT no email NO TRADES
    ***can arrange for frame to be finished or any other fab work to be performed but will need to be discussed outside of purchase of this ad ***[​IMG]
  2. rat nasty
    rat nasty
  3. rat nasty
    rat nasty
  4. rat nasty
    rat nasty
