Customs Gambino taildragger on a '53 Chevy
Discussion in 'The Hokey Ass Message Board' started by brooksinc1976, Apr 25, 2017.
  1. brooksinc1976
    brooksinc1976
    from P-Town
    Haven't seen a vid on this setup so I figured I'd stutter through one. Here's my progress. Full disclosure I'm a pretty green at this so be gentle. I'll be adding updates as I go so feel free to critique.
  2. Hot Rod Cowboy
    Hot Rod Cowboy
    Looks like you're off to a great start. There's quite a bit of info/pics if you just google "Gambino notch" and I've always heard Alex is really good about product support for customers. Looking forward to more!
  3. brooksinc1976
    brooksinc1976
    from P-Town
    Thx. Yes I looked and looked and one of the reasons I went gambino I no real negative reviews and great support. Hack I've already asked him lots of stupid question that he is happy to help.
  4. 57JoeFoMoPar
    57JoeFoMoPar
    Alex is a good guy. I recently purchased a Fatman MII frame clip through him and he was very easy to work with, made sure I got what I needed.
  5. ahshoe
    ahshoe
    Heres a few of pics of my" Gambino notch" on my '51 Ford
  6. brooksinc1976
    brooksinc1976
    from P-Town
    A little closer, got rid of the perches. [​IMG]
    My buddy canceled on me so I pondered a while how I was gonna go from A to B.
    One a hernia later
    Here's where it really got stupid. Got it in place thanks to all the crap I could find and a lot of zip ties...
    She's tacked in and holding. I left the super zip ties just in case. Ha
    Got the 1st part of the C notch in. I used 3/4" sq tubing to space the top. Next step get the 4 link on and finish the C. Oh did I mention I double checked myself about 100 times. Hopefully I'm squared up.
  7. What size wire are we using here?
  8. brooksinc1976
    brooksinc1976
    from P-Town
    035 says the gorilla... I'm waiting on my buddy to hold my hand on the welding. That's why the top plate Of the notch is not on.
  9. Caddy-O
    Caddy-O
    Looking Good !
  10. That's what I thought. That's a big Miller welder ...210-230, something like that?
    Too big for that job. Hard to get a nice looking weld...in MY opinion.
  11. brooksinc1976
    brooksinc1976
    from P-Town
    Is an old 200 Miller. Old faithful. I'm doing things backwards. I'm practicing after I already started
  12. xpletiv
    xpletiv
    from chiburbs
    brooksinc1976 likes this.
  13. brooksinc1976
    brooksinc1976
    from P-Town
    Ment to post this earlier. Here's measurements I came up with
  14. brooksinc1976
    brooksinc1976
    from P-Town
  15. 49ratfink
    49ratfink
    you need to stop and learn how to weld better. this does not look good at all.
    chop job, harpo1313 and X38 like this.
  16. brooksinc1976
    brooksinc1976
    from P-Town
    harpo1313 likes this.
  17. Better keep buyin' the beer for your buddy. See, on that frame bracket stub. I'd put the tacks on the corners, then weld from tack to tack, then tuck the wire up under the end of the bead ,and do the vertical next. It will look a lot nicer that way.
  18. brooksinc1976
    brooksinc1976
    from P-Town
    lawman likes this.
  19. brooksinc1976
    brooksinc1976
    from P-Town
  20. brooksinc1976
    brooksinc1976
    from P-Town
  21. brooksinc1976
    brooksinc1976
    from P-Town
    mario711 and johnnyknuckles79 like this.
  22. mgtstumpy
    mgtstumpy
    Coming along nicely, could I suggest gussets on the lower frame brackets as the Chevy is only top-hat style frame. A bit more strength will stabilize it better and deal with it being loaded and unloaded as you drive and corner.
    Also how much thread have you got inside the 4-bar tubes, it looks like adjustable ends are screwed almost out? The ends need to be screwed in 3/4 of their threaded length. That way you leave room for adjustment.
    brooksinc1976 and Poh like this.
  23. Hot Rod Cowboy
    Hot Rod Cowboy
    I agree with mgtstumpy; those lower 4-link brackets on the frame need a gusset going forward towards the motor at the minimum. Under acceleration, the axle will try to rotate counter-clockwise (as view from the passenger side of the car), so the lower link will try to push forward/up. The metal on the top hat style frame is pretty thin and I wouldn't trust it the way you have it now.
    Better yet would be to connect the two mount brackets together to form a cross member. You'll have to figure out a drive shaft loop in the middle, but it would be WAY stronger.
  24. Poh
    Poh
    from Quincy,Ca.
    Looks like you need to speed up your pace, or turn down the wire speed, and clean all that you are Welding to new steel. Looks like you are dragging , you should try pushing.
    johnnyknuckles79 likes this.
  25. brooksinc1976
    brooksinc1976
    from P-Town
    Thx. Got some gussets, just didn't put them on. Guess I need to. The threads are half way so I could adjust each way as needed
    Poh likes this.
  26. brooksinc1976
    brooksinc1976
    from P-Town
    I thought about that. I haven't seen any pic on the web like that for the gambino but I was thinking that would be stronger.
  27. brooksinc1976
    brooksinc1976
    from P-Town
    Thx. It's been a learning experience. The better welds are my buddies. I get credit for the crap.
    Poh likes this.
  28. brooksinc1976
    brooksinc1976
    from P-Town
    VintageConcepts likes this.
  29. brooksinc1976
    brooksinc1976
    from P-Town
    [​IMG][​IMG][​IMG][​IMG]
    Low as I'm gonna get it. Got some 10.5" trailer fenders to fab in now.
  30. brooksinc1976
    brooksinc1976
    from P-Town
