Looks like I got your attention with my heading.i have a 30 model a coupe.on 32 rails.sbc .question is I'd like to run a Muncie.but don't like shifter location.is there any other trannys That would have a better shifter location?ie not so close to seat.i read t&f used to make a top mount shifter for Muncie,but no longer made.
Look at a HURST shifter for a '55-'57 Chevy. They are designed to clear the bench seat. Before I discovered this shifter, I made my own arm to move it forward to clear the bench seat in my '53 Chevy truck. Good Luck, Tim
Think about a T5. Standard or "world class". Five speed and you can get a forward shift mount. Put one in our 32 behind a flathead. Works like a dream....................
Get a tremec and put the shifter in the middle position. Problem solved. Plus an overdrive. You didn't say cost was a factor.
There used to be some Hurst shifters for the Saginaw's that mounted pretty close to where the extension housing bolts to the case; truck or Jeep applications? Muncie's and Borg Warner T-10's both have the reverse lever on the extension housing, so they're in the way of a shifter mounting, but all three levers are on the side cover with Saginaw's. I'm not familiar with the "rail shifter" transmissions (T-5's and similar). I am Butch/56sedandelivery.
Hurst shifters have some adjustment, they can leaned forward or back. The slot on the lower left is the adjustment. A link to Hurst shifter sticks. http://www.hurst-shifters.com/product-category/?slug=shifter-sticks-service-parts
I've gained room on a few Hurst shifters by rotating them forward five to ten degrees. Some are easier than others, depending on whether the mount is a flat plate or the stamped steel version, most have enough adjustment in the rods for this. Leave the big center bolt slightly loose then rotate forward and transfer the other attachment bolt locations and drill and tap the mount. On the stamped steel type mount I made a threaded insert and welded it in at the new location.
I used a shifter for a 70 chevelle with a console. It put the shifter in the center of the car handle is a pick up one worked perfectly. The package tray was removed might not work with package tray in. A link to Hurst shifter sticks. http://www.hurst-shifters.com/product-category/?slug=shifter-sticks-service-parts[/QUOTE]
If you have a Hurst tower of the bolt on handle variety the options are endless. Some of the console sticks kick over to the passenger side , while others will kick forward. Over the years I have both cold and hot (with quenching) bent quite a few for a just right placement. The trick is to start with a long enough handle to end up with the top where you want it. It helps to have enough raw material : IMG_3746 by bowie posted Aug 1, 2014 at 6:57 PM
Call Hot Rods and Custom Stuff in Escondido, 1-800-hot-rod-5. As of a year ago they were selling the T&F shifter for the Muncie 4-speeds. I don't know if they're still available.
Very interested in how you did the linkages. I'm about to start fitting one in an A model. That reverse arm would be working in the opposite direction?
Just go with an S10 5 speed, beef it up a bit and its every bit as strong as the Muncie (They weren't very strong anyway). Plus you get OD.
I have one in my model A, I made it work. If you can cut weld fab this will work. If not just scroll down to the next thread where they tell you to just use a trans you don't have. I used the hated 4 speed shifter from a vega. The shifter mounts to the center of the trans tunnel so the shifter levers on the bottom are long and bent to the side for the linkage. Mount it to your Muncie... on top where you want it. your only issue is reverse so start with the reverse linkage . You may need to relocate the shifter till reverse linkage works. cut drill weld a flat iron to the top of shifter where you cut off the original shift handle. bolt on (the usual 2 hole hurst mount) a handle that works. I used a push spring in the shifter, so now it hold the shifter to the left like a real shifter. Oh it now is to high to use a small boot, so use a Hurst super boot! Works great NO issues after 40K miles
This is one way to solve the problem: I succeeded in fabricating a center shifter for the Muncie tranny After studying Tanos's pics, I fabbed a similar solution in my model A. To further complicate everything, I not only had to center the shifter - i had to move it backwards and raise it up too. Took some thinking, building, rethinking and rebuilding before I got it to work.
