Technical Is anyone still using 4 speed transmissions?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 13, 2017.
  1. DYNODANNY
    DYNODANNY
    Im running a muncie M20 behind the 241 hemi in my 36 pickup truck. Using a 57 bellhousing and a Hurst verigate shifter.
    Sent from my SAMSUNG-SM-G935A using The H.A.M.B. mobile app
  2. 4 speed wide ratio toploader behind a 351w going in my '34 coupe! This will drive a 9" with 3.25 gears and 30" firestone bias plys. Still busy building it but hoping this will be a good compromise for pull off and cruising!
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    hendelec, car doctor and Runnin shine like this.
  3. butchcoat1969
    butchcoat1969
    I still use one I have a Muncie I ve had sitting in my garage that I put in my 57 Chevy I also run a 700R4 when ever I get tired of shifting I just throw it back in it only takes a couple if hours and I'm back on the road although I'll admit I'm starting to get bored with switching them out lol
    chevy57dude likes this.
  4. ^Hell of a lot o' work!^
    The '57 runs an M22. Love to hear it sing. Looked like some on this thread, nice and clean. Till you fill 'em with 90wt. Then they seep due to porosity. Here's a mystery: IMG_20160110_083353871.jpg
    This is a 3 speed GM iron case something. Low 1st, like 3 to 1. Does anyone know what it is?
    lothiandon1940 likes this.
  5. 41GASSER
    41GASSER
    40FORDPU and lothiandon1940 like this.
  6. graveyardsledder
    graveyardsledder
    I love my Saginaw 4 speeds, I don't beat it up and it's been a good transmission. Got a couple of 3 speed sags too.
    '51 Norm and lothiandon1940 like this.
  7. Hubes45
    Hubes45
  8. southcross2631
    southcross2631
    I am building this 57 for a customer and it is getting a Saginaw. 2015-03-13 10.57.50.jpg
  9. The shifter I'm using I bought in '78 for my '65 Belair. The stick needed a tweak to clear the bench seat in my Ford.
  10. I've got TWO Muncie 4-speeds, both M-21 variety. One was and will be in my '46 Chevrolet PU and the other was picked up during my buying spree. It's a spare for the truck or the trans of choice for my "third project" that I want to build someday. (No, I haven't bought another car...but I'm looking for a steal!!!)
    Runnin shine likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
  12. Racerex
    Racerex
    I have the same exact setup in my pickup and it works great.
    Sent from my SM-G930V using The H.A.M.B. mobile app
  13. 612DOR
    612DOR
    I started out with a toploader in my Falcon behind the Cleveland but 3000 rpm at 60 was a bit much. T5 now and 2200 rpm. Buildind a 52 F1 and just sources BW OD for it. Best of both worlds. 4.11 rear and od!
    Sent from my SM-G925W8 using The H.A.M.B. mobile app
  14. You could hook up a column shift to a 4speed.... just run a reverse lever like my old Verti-gate had..... I thought about this years ago just for something different....
  15. 57Custom300
    57Custom300
    from Arizona
    Toploader in my 61Starliner. T5 in my 57. The T5 made the 57 a blast to drive over the 3sp. Wouldn't hesitate to run a T10 in either car.
  16. butchcoat1969
    butchcoat1969
    Yep I do that move back and forth every year when I want to shift or just drive, the best of both worlds lol just takes a couple of hours to change it out lol, I like the shorten wagon idea I've seen them before and think theyer really cool looking, there use to be a black 4 door 55 Chevy that a guy shorten to a coup with a bomb exploding on the back quarters he named the bomb, it was the coolest 55 I've ever seen, I Lov the engineering that you hot rodders have and come up with I hope it never dies out but it looks like it's headed that way sorry to say, they need to start offering classes on how to build hot rods in every state imo lol
    Sent from my iPad using The H.A.M.B. mobile app HotRod Harry
  17. butchcoat1969
    butchcoat1969
    Very nice setup, looks like mine lol
  18. butchcoat1969
    butchcoat1969
  19. rbantique
    rbantique
    from maine
    MMM1693, dana barlow and Runnin shine like this.
  20. It's just like everything else. There's definitely still some die hard 4 speeders out there. But as 5 and 6 speeds are becoming more readily available, gear jammers are seeing the the benefits of those extra gears. Especially since most 5 and 6 speeds have such high lower gear ratios, there's no real street reason to run ultra high rear gearing. Not to mention that pesky vacuum problem avoided when running a big cam and a automatic.
    Sent from my SM-G920V using The H.A.M.B. mobile app
    redlineracer42 likes this.
  21. quicksilverart46
    quicksilverart46
    I love the M21 close ratio behind the 301 in my '59 Apache. I have run sticks in all my cars since 1968. Just say NO to slush boxes!!t[​IMG]
  22. I ran a Sag once with a 3 speed shifter and jus threw it into neutral and pulled the reverser with a linkage I had sticking through the floor. I am sure that most guys are not that backyard though. :D
    You could actually hook reverse up to a choke cable or an E brake handle. ;)
    I haven't heard anyone call an automajic a slush box since my Ol' Man when I was a kid. :D :cool:
    bowie likes this.
  23. bowie
    bowie
    Hubes45: A hydro is a 50's GM automatic that dominated several drag classes for years. In the hands of guys like B&M they were very tough to beat.
  24. quicksilverart46
    quicksilverart46
    I might as well add a photo of the trans in my '46 Chevy Gasser. Its a Tex Racing magnesium case with 9310 nickel alloy straight cut spur gears with dog ringface tooth engagement used in NASCAR. The gears are splined and changeable with hundreds of ratio combos available. It has a sweet whine and with the Hurst super shifter it bangs gears like greased Lightning![​IMG]
  25. bowie
    bowie
    Chevy57dude: To me that tranny looks like the Muncie version of a T-85 BW 3spd, reminds me of one we had to jerk out of a heavy duty C10 of about '69 vintage. Definitely could be wrong, though.
  26. harris73085
    harris73085
  27. dan c
    dan c
    i've considered that one for my shoebox. aren't the super t10 dimensions close to the stock 3-speed?
  28. SinisterCustom
    SinisterCustom
    Only real men use 4 speeds....
    Sent from my SM-J700T using Tapatalk
  29. Kan Kustom
    Kan Kustom
    Have a Muncie 4 speed in my 40 coupe, 70 Camaro and 57 Chevy 210. Two more for next projects. Whether or not there are better options I just like em.
    spikeshotrods and lothiandon1940 like this.
  30. toyshop1
    toyshop1
