33-34 Ford Steering column drop with original Hurd lock cylinder with two NOS keys (one is brass the second is nickel finish) both keys operate without a hitch, rubber mounting cushion, new metal dash reinforcement, new mounting bolts, NOS pinch bolt, new thumb switch handle, new ignition switch back plate, new bright hardware as pictured below. Including the column center shaft lock collar with it's two special set screws. $280.00 I will pay the USA shipping. Send me a PM for more photos.
