Custom bead rolling....lotsa pic's
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Nov 25, 2006.
  1. PKap
    PKap
    from Alberta
    I have a technical question that I am hoping someone who is posting on this thread can help me with. I have been playing a little with a roller, and when working on light aluminum and light weight, the little bit of distortion is no big deal to straighten out. I tried a test piece for a firewall on my 53 chev. Using 18ga steel I put in 5 fairly deep steps to get the backset I wanted for the 472 I'm using. I ended up with over 1" of bow forward at the bottoming the piece. That is 2" from where I wanted it. I know some of it will relax when I cut out the trans tunnel (about 5"x 16" at the bottom). I don't want tension in the panel. I don't have an English wheel to pre stretch the panel before I bead it, is there a way to do this without a wheel? Could I add a bead in the design that would gather up some of the stretched material? Is there a way to shrink this after beading other than heat? I'm not sure how or where to try heat shrinking. Any advise would be greatly appreciated. I don't mind experimenting as this is more of a test piece to see what will work.
  2. PKap
    PKap
    from Alberta
    I keep getting a message that it is not an image file, even when I use the camera icon to post. Used to work fine.
  3. PKap
    PKap
    from Alberta
  4. cornfieldcustoms
    cornfieldcustoms
    if you dont have a wheel to pre stretch the panel you can use a hammer and dollie, with on dollie hammering to stretch the panel. it takes a while but works
  5. PKap
    PKap
    from Alberta
    Thanks for the reply to my question. On a panel like the firewall, would I give it a 2" crown centred at where the bottom beads are? I have a planishing hammer, so that would be faster. If I just do a spiral pattern with that and a low crown anvil, I can get a nice shallow bowl shape. My question would be if I am better to start with a crowned panel, or if I should just run the hammer and stretch along my planned bead lines?
    I sure appreciate what you guys can accomplish with a roller and I am having fun figuring out how to get the results I am after.
  6. cornfieldcustoms
    cornfieldcustoms
    i always just stretch right where the bead goes, and then the panel will be flat after it is bead rolled
  7. MP&C
    MP&C
    Make a couple of wide radius dies for your bead roller, you should be able to use it to prestretch since you don't have a wheel...
    Where I was using this with a skateboard wheel to add radius to a panel, two wide radius wheels aligned together in your bead roller with pressure applied should work to add some stretch to the panel prior to beading..
    bct and YocumBros. like this.
  8. wide34
    wide34
    from Texas
    Great way to do it! Many thanks for taking the time to post it.
  9. PKap
    PKap
    from Alberta
    That's a great idea! Thanks, I'm going to make one right away. I was wanting to have flat panels between the beads, and wondering how to achieve that.
  10. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    This is from a customer of ours in Germany
    dana barlow likes this.
  11. heyitsnate
    heyitsnate
    Floorpans! 1936 ford
    bct and bigbore like this.
  12. Nicely done; gonna be a shame to cover 'em up!
  13. hrm2k
    hrm2k
    I helped a friend build his car a few years ago. We used my Woodward Fab bead roller............he loved it. When we were done, he bought a good bead roller ( Jamey Jordan signature model ) and made a panel for me as a thank you. It is the exact same size as the grill in my car. It was his first real piece he did..............I still marvel at it every time I see it
    fordsbyjay and 117harv like this.
  14. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
    Some recent work:
    diamonds_door_quarter_2.JPG Brad-Ocock_dragster.JPG pleats_with_VW_logo_door.JPG extractor_racing_door.JPG 405_door.JPG intermountain_transco_3.JPG .
    iagsxr, LTM75110, 54reno and 3 others like this.
  15. brady1929
    brady1929
    ^^^^Damn you are good^^^^
  16. wisdonm
    wisdonm
    The seats and door panels look great, but I'd cray if they got dinged.
  17. BigWigRaceCars
    BigWigRaceCars
    from Austin, TX
  18. Big Swede
    Big Swede
    I'm in awe over the quality work in this thread! Thanks for sharing!!
  19. 1lucky1
    1lucky1
    from Morgan NJ
    Excellent work everyone, Allways amazed when I see the work,Love the Diamond type door panels, Would love to see them done in copper, then aged! Merry Christmas to everyone, Lucky
    RODIST likes this.
  20. Your wish is my ......... Not mine .
  21. 117harv
    117harv
  22. ncjamey
    ncjamey
    brady1929, IowaMercMan and JOYFLEA like this.
  23. ncjamey
    ncjamey
  24. ncjamey
    ncjamey
    Fern 54, brady1929 and 54reno like this.
  25. ncjamey
    ncjamey
    IowaMercMan and brady1929 like this.
  26. ncjamey
    ncjamey
    JOYFLEA likes this.
  27. Friend [Tony Humphries] did my door trims on my pickup. He is doing some pretty nice work from home in Perth West Australia. 20170121_162229.jpg
    Fern 54, JOYFLEA, brady1929 and 2 others like this.
  28. ncjamey
    ncjamey
  29. ncjamey
    ncjamey
    JOYFLEA, clunker and Sinister like this.
