Anyone have a good pic or pic's of a '34 Ford Commercial size Headlight mounted on the headlight bar? Interested in seeing how the wiring cover from radiator shell to headlight hooks up to bucket, etc. How do I know I have '34 Ford commercial headlights? Thanks!
To start with, rim and lens are same as '34 passenger...consult about any olde Ford parts catalog. The streamlined stainless rear shell of the passenger light is replaced by a plain steel shell that is much smaller, pretty much the minimum size to cover up the reflector.
I got my headlight buckets off of this. '33-'34 Ford....I believe this is a commercial truck. Not sure if this will help, or not but the wiring goes through the big hole in the center. The other four are the mounting holes to the bracket (last photo). And, this is the bracket that bolts underneath the bucket...............
OK, I'm confused. In the first pic, you can see them mounted on the original truck. Is that not a '33-'34 Ford commercial truck? The truck has been sitting in that spot since the '50s.
I am totally confused by this too. I mean, surely a guy with a 20 yr old dump truck in the 1950's would have been aware that the use of a sealed beam conversion would be a 10 point deduction under Early Ford V-8 Club of America judging, right? What the HELL was he THINKING??!!
"I'm sure these are aftermarket" The ones on the truck or the ones on...oh, never mind. Headlight swaps were VERY common starting in 1940, when sealed beams became widely available. All the light companies put out swivel type headlights with sealed beams made as almost universal swaps for all those early cars out there.
Be careful when looking at the '33 and '34 headlights. I am fairly certain they are a slightly different shape. Charlie Stephens
Here's what I am working with. No hole for wires, hole in mounting bolt only. If I use the hole in the mounting bolt what does the wire conduit look like where it bolt to mounting bolt?
'33 passenger. at least early ones, had a longer light than '34, but the commercials I think were all the same with an ultra-short cone behind the reflector. I believe trucks from '32-up with wires in the open got a simple and ugly conduit made of the same woven black stuff used elsewhere on the original wiring system...special grommet or metal ring where it went into the grill shell.
To see close up pictures of the light, I suggest you go to the Bob Drake catalog or website. In addition to the lights, I believe he also sells conduits for this application. Sent from my Nexus 7 using The H.A.M.B. mobile app
We've made 2 orders with Drake and non of the parts sent look rite to me. On a '34 P/U does the wire go threw the mounting bolt or not?
Hope these pics help, 33/34 commercial, not sure of any differences between years. The conductors go through the bolt then through a conduit to the grille shell like a Model A. All the Best, Michael
OK, So I believe it's correct to say the wires go up threw the mounting bolt, now how do you attach the wire cover metal/loom/conduit/sheath to the bottom of the bolt?
I'm going to guess that if you had these in your hands with the headlight in front of you too it would be pretty easy to figure out. Looks like the big end goes over the nut
Again, I suggest you look at the pictures of the conduits on the Drake website. You can buy them elsewhere. I used and extended flair nut from the plumbing department. It threaded on the mounting bolt just fine. Drilled it out so my conduit would enter. Put a set screw into the side to hold the conduit. Not sure what Ford used on the commercial in 33 & 34. Sent from my Nexus 7 using The H.A.M.B. mobile app
Vintique sells replacement bolt that can be cut as needed. Sent from my Nexus 7 using The H.A.M.B. mobile app
That was my first disappointment, the short bolt. Don't like the 2 dimpled way of doing it so will have to think out of the box like pprather. Thanks to all!
I bought a 34 big truck last week .the wires go through the bolt and it has remains of a black wire cover taped to the bolt.
I think we pretty much proven the corrugated wire cover with the 2 dimples just slips onto the nut. I was overthinking it because I couldn't believe Ford would have designed such a "funky" way of doing it....................................................
