Blown 56 chevy gasser build for 2017 meltdown or bust
Discussion in 'The Hokey Ass Message Board' started by fast30coupe, Jan 19, 2015.
  1. fast30coupe
    fast30coupe
    from Illinois
    It's the angle of the picture. Il take some better ones next time I was In a hurry. It's close to the pitman arm but there shouldn't be and issues even in worse case scenarios. The nut make adjustments easy. I plan on chroming all the drag links and small linkage so the nut will hopefully prevent chipping the chrome.
    loudbang and Hudson31 like this.
  2. blownhemi48
    blownhemi48
    from Bergen NY
    I wasn't explaining anything. It's the video where the engine destroys the dyno room. But I did ask Jim Oddy why he was running collector headers instead of zoomies on his '33 Willys AA/G car when he had the small Chevy engine in it. He said it made no difference. Now if you think you're smarter than Jim Oddy, you must be a genius. If it makes you feel better, he does have zoomies on the Hemi he replaced the Chevy with. But I think it has more to do with packaging than anything else.
    NHRANUT likes this.
  3. blownhemi48
    blownhemi48
    from Bergen NY
    I don't know if they still sell it but Speedway had a mechanical water pump for injected sprint cars that mounted between the timing cover and Hilborn/Enderle fuel pump. The drive spud went through the water pump and engaged the fuel pump.
  4. fast30coupe
    fast30coupe
    from Illinois
    I believe they still do, but would cause clearance issues with the blower belt. There are a few water pumps like that available I just though this would make things easier.
  5. That nut on the shaft is a great idea. Mine is all mangled from using vice grips at the track. What water pump is that?
  6. Okiedoker
    Okiedoker
    from Wisconsin
    You had to get some work done during the warm weather streak....where is the update man?
    You can't beat a red 57 if your car isn't done!
    loudbang and saltflats like this.
  7. fast30coupe
    fast30coupe
    from Illinois
    You know how life goes. Ended up moving last weekend and got engaged. So my fiancé is wearing my motor on her finger right now haha. I did sneak in a day in there some how though. I bought new Calvert mono leaf springs for the rear to save some weight but the arches were a little different than the ones I had. This completely altered my rear suspension geometry. So after loosing a few nights sleep. I decided I wanted to change my ladder bars anyways and make them more gasser looking. So I ordered rod ends and bungs. So I have been doing things and planning just no pictures to show for it. One step forward two steps back. Should change the name and put rebuild in there somewhere. I was going to email you and tell you to cross my name off the list haha there might be hope still. Hopefully when it gets nice I will start working on the car at night.
    Dog_Patch, racer-x, loudbang and 2 others like this.
  8. Okiedoker
    Okiedoker
    from Wisconsin
    Congrats on getting engaged. There are a few things more important than cars.
  9. Bugsy48
    Bugsy48
    True, but very few.......
    klleetrucking and loudbang like this.
  10. fast30coupe
    fast30coupe
    from Illinois
    Messed around at work today.
    This is what I'm thinking for the new ladder bars
  11. Only thing I would do different is put the adjuster on the top bar rather than the bottom. Im guessing thats why the bottom bar is shorter than the top? Then it's hidden out of plain site.
    Sent from my SM-G930R4 using The H.A.M.B. mobile app
  12. fast30coupe
    fast30coupe
    from Illinois
    I was kinda thinking that. I guess it doesn't really change anything design wise. It might actually be a stronger design considering the bottom bar takes most of the hit.
    BLACK STUDE, Dog_Patch and loudbang like this.
  13. whats the overall length and with a stick shift blown car are you going with solid 1 inch front heim joints. hint hint.
    mad mikey and loudbang like this.
  14. fast30coupe
    fast30coupe
    from Illinois
    Not sure on the length yet. Im going to go with an aurora chromoly rod 3/4 rated at 28,000lbs plus.
  15. fast30coupe
    fast30coupe
    from Illinois
    Mounted up some new slicks on some wheels I had
  16. fast30coupe
    fast30coupe
    from Illinois
    Insanity
    Had the rear end in and out of the car a bunch of times figuring out ride height and taking measurements.
    Welded up the front mounts missed being behind the helmet.
    Should start making the ladder bars next weekend.
    A few more pay checks and you should see some boxes with a Mw on them.
    mad mikey, Butch M, cs39ford and 4 others like this.
  17. fast30coupe
    fast30coupe
    from Illinois
    Back at it. The rear springs are from Calvert racing. They didn't send me the hardware for the front. So they sent me some. Whoever pressed the front bushings in made eggs out of them. Instead of calling and bitching I fixed then myself. The hardware they sent looked like garbage. The drill walked all over the place. So I just made my own. Then I know it's right. Also made some adjustment to the spring sliders they sent. So much for American manufacturing.
    Here's the hardware I made
    You can see they did quite complete the bend
    When I was done top and bottom were within .010". Maybe I'm just crazy
    And I finished the debuting for them
    Mounted
    Rear is in the car with weight to settle the springs
    Next make the ladder bars and weld the slides in.
    Butch M, loudbang, cs39ford and 2 others like this.
  18. Such a great build! Good times ahead.
    loudbang and mad mikey like this.
  19. looks good
  20. fast30coupe
    fast30coupe
    from Illinois
    Thanks kiwi Kev.
  21. fast30coupe
    fast30coupe
    from Illinois
    Thanks Brian, no updates this week?
  22. pigfluxer
    pigfluxer
    That's the way you do it on the MTV........
  23. I had a conference I had to go to for work. there is a lot of continuing education we need to stay current on. maybe some updates soon.
  24. fast30coupe
    fast30coupe
    from Illinois
    No ladder bars yet. Waiting on another piece of material and I want to make them both at the same time so they are exactly the same and it will be easier to do the notches.
    I did clean off the old ladder bar brackets
    I also welded the bottom of the back frame section. I'm giving the springs a little more time to settle before I weld the sliders in.
    Here is a mock up shot
    I just wanna make the ladder bars and roll it out side
    Butch M, saltflats, loudbang and 2 others like this.
  25. Hatchet
    Hatchet
    Absolutely loving this build and your attention to detail. Keep us posted!
    Sent from the Confederate State of Arizona
    fast30coupe likes this.
  26. fast30coupe
    fast30coupe
    from Illinois
    Thanks hatchet appreciate it.
    Hatchet likes this.
  27. fast30coupe
    fast30coupe
    from Illinois
    More mock up. Still waiting on tubing guess the had to mine the raw material or the order never got placed
    Did refine the ladder bars a little to make them easier to make. Yes they are a knock off of a Quain stott design. Your only going to see the bottom of them anyways.
    Hopefully this weekend I can get these made.
  28. fast30coupe
    fast30coupe
    from Illinois
    Got one side done
    A 10 degree notch isn't the easiest thing to do.
    I could only do a short section. Then had to print cope in solid works to give me a pattern to finish the rest.
    I'll take more pictures when I do the next one.
    Made a dumb mistake and cut the other side to short. At least I did it before the notch. I mixed the finished one up with the not finished one they were both to close to the bandsaw
    mad mikey, Butch M, saltflats and 5 others like this.
  29. fast30coupe
    fast30coupe
    from Illinois
    As promised the cope. The lady was getting her haircut so I grabbed another piece of tubing
    Notched tubing and template. The template is on sticky paper from office max
    I step in with the bridgeport to rough and a grinder to finish
    A little more fine tuning and it will be good to go
    Butch M, loudbang and saltflats like this.
  30. fast30coupe
    fast30coupe
    from Illinois
    Finished the second ladder bar.
    I bolted them together to make sure they were the same length.
    Here they are mocked up in the car
    I'm ready to roll this thing outside already. Still a lot of work to get to that point.
