Hot Rods How much does a hot rod weigh?
Discussion in 'The Hokey Ass Message Board' started by 35chevy, Feb 10, 2017.
  1. 35chevy
    35chevy
    I know the 3x2 setup won't make as much power as a single 4 BBL, but it's a must have. Form before function as long as it somewhat still functions. Open fendered cars with a single carb = boring.
    3340 likes this.
  2. 35chevy
    35chevy
    It shouldn't be that unrealistic in a light car with traction. I ran a 7.75 in a Ford Ranger truck at 3300 lbs with a 5.0 with Explorer heads and intake, and a T5 with 4.10 gears. That pass was on slicks leaving at around 2000 rpm because it was light in the rear and had traction issues. It made 276 hp to the wheels, and the 7.75 pass was using a dry nitrous system jetted at 80 hp. The truck only made 337 to the tires on the nitrous. I never had it on a 1/4 mile track, but that should be 12.0's or 11.90's. Now, factor in that the Model-A is 1000 lbs lighter, it shouldn't be unrealistic at all. Surely a properly built y-block with some good traction can keep up with a junk yard 302.
  3. 35chevy
    35chevy
    That's what I'm talking about.
  4. Flathead Dave
    Flathead Dave
    from So. Cal.
    I weighed a weight.
  5. They still gave a damn about them in La Mesa, Ca. a couple of years ago. Fortunately, the city figured out the Thursday night cruise was better for their PR and pockets than the tickets, and stopped assigning officers that didn't want to be there. Sad thing is, the damage was already done, and there are numerous people I know who won't go there. Hell, I'm even a little hesitant about taking the T there, I usually drive the '48. Now, back on subject, it's pretty hard to come in under 1500 lbs., my T weighs 2,000 (admitedly, there are several things that could be done to make it lighter, but I'm not racing it on a regular basis, so why bother). You can have a drive able, 12 sec. Model A (my neighbor had one for years, a '28 closed cab pickup) and he regularly took it to the track and ran 12:60's, and he also regularly ran around the neighborhood with his kids in the bed (back when that wasn't illeagal!). I don't know all the details of his combination, but it was a 375hp 327, turbo 350, and a 9" rear end, and I believe 4:11 rear gears. Pretty sure it had buggy springs and 4 bars for suspension. Anyway, as others have said, build something you're going to enjoy driving, then sneak up on those 12's. It's going to take a lot fine tuning to create a usable 12 sec. car.
  6. tfeverfred
    tfeverfred
    With or without the owners ego?:D
    Larry T, Blownfuel and denis4x4 like this.
  7. deathrowdave
    deathrowdave
    from NKy
    My Henry 32 , SBF , auto , 9in with me in the seat weights in 2380 with full tank of gas .
    gnichols and rod1 like this.
  8. Malcolm
    Malcolm
    from Nebraska
    My Model A Roadster on '32 rails weighs 2320 lbs. with me in it (I'm 160). It has a 347 SBF and T5 (w/ scatter shield) in it, 4.11 geared 28-spline Ford trac-lok 9". The 347 is supposed to be around 400hp (bought it used) and the best I've run is an 11.95 @ 113 mph. 1/8th mile, I run mid-7s around 91 mph. On the track, I run 29.5x7.00-15 M&H Racemaster slicks. They've worked out well and do stick. I imagine I'd end up with better ETs if I were to run an automatic. The T5 doesn't like the abuse and it's hard to hit 3rd gear sometimes.
  9. Here is a starting place for you:
    Note: weights are approximate and assume gasoline tank and radiator are empty)
    Vehicle Weights
    "A" chassis 1650
    Sport Coupe 2283
    Open Cab Pickup 2073
    Tudor Sedan 2375
    Roadster 2155
    Panel Delivery 2416
    Phaeton 2212
    Fordor (3 window) 2462
    Closed Cab Pickup 2215
    Fordor (2 window) 2467
    Standard Coupe 2257
    Town Sedan 2475
    Cabriolet 2273
    Station Wagon 2482
    Deluxe Delivery 2282
    Taxi Cab 2500
    Bodies
    Roadster body 465
    Tudor Sedan body 726
    Phaeton body 549
    Fordor (2 window) body 782
    Cabriolet body 575
    Fordor (3 window) body 786
    Coupe body 591
    Town Sedan body 810
    Sport Coupe body 596
    Miscellaneous Parts
    Bumperettes 46
    Tire/tube (19") 20
    Cowl Tank & dash 43
    Tire/tube (21") 18
    Front bumper 34
    Wheel (19") 21
    Rumble seat 55
    Wheel (21") 22
    Tools ("A") 14
    Wheel carrier 10
    On a coupe you are hard pressed to loose much weight. Best bet is if its bare bones that it is still going to be pretty close to stock you may loose 100 lbs if you really trim things.
  10. My 32 and the 51 both have creature comforts and insulation and sound deadener. They both weight inbetween 3200 and 3300 lbs with half a tank of fuel. This is on the scales at the grain elevator. Both have 5 speeds and v8s.
  11. treb11
    treb11
    As little as possible and still hold together
    tfeverfred likes this.
  12. Blue One
    Blue One
    from Alberta
    Losing weight will be really easy if you leave everything loose :D
    Then you can drive down the road losing loose parts and the weight loss will quickly add up :D Maybe even as much as that 100 pounds :);)
  13. southcross2631
    southcross2631
    Those computer generated times are great. Now jump on your key board and go run 7's.
    What temp,? what elevation ? what humidity ? How much aero drag ? what tires ?
    Who's driving ? Is the track prepped ? They are WAG times. That's wild ass guess times if you didn't figure it out.
  14. southerncad
    southerncad
    FWIW, my "hot rod" weighs right at 4,000 pounds:eek:
  15. El Caballo
    El Caballo
    3...but....
    anthony myrick likes this.
  16. Kirk Hanning
    Kirk Hanning
    This one weighs 2600 lbs
    sbc/350 turbo/9" rear axle
  17. seb fontana
    seb fontana
    from ct
    how far into the woods can you go?
  18. tubman
    tubman
    To get back to the real world, all I can add is that I've had two of my cars weighed on state certified scales. The first was my "T" bucket I built in 1965; I had to have it weighed to get the registration. It was a steel front of a '23 "T" touring on a home-built tube frame with a 270" '55 Dodge hemi and a Dodge 3-speed. It came in at 1835 lbs (no fuel, no driver). The second time was when they said I cheated with my Hemi-powered dirt modified. It came in at 2250 and I came out OK. These numbers are supplied for reference only.
  19. My '31 pick up weighs precisely 2060 wet. No fenders, hood or side/rear glass. Has a flathead, top loader 4 speed and a 9 inch. Frame is un boxed with a Tardel K-member. I know the weight because one of the conditions of getting a title issued here for pick ups is that they have to go to the weigh station first.
  20. topfuel55
    topfuel55
    from Hebron IN
    283,Muncie, 9 inch, all hand built from there... 1900#. No clue as to any ET, though.
  21. Speed~On
    Speed~On
    Here is my Model A on the scales last Spring. I was curious as to what it would weigh, so I drove over to Landmark Agriculture in town to find out. It weighed in at 2,380 lbs (without me in the car).
    I have a SBC 300 HP with a TH350. 9" Ford posi rearend with a Currie center carrier, 3.55 gears. Its a no nonsense car with the intent of weight being kept to a minimum.
    My suggestion is that you build the strongest drive train as you can; you'll never go wrong doing that. A 9" Ford rear end with posi traction, Strange or Currie axels and center carrier, etc.
    As far as your desired ET in the 1/8, I think it's just a matter of you building your car with the money you have and your goals in mind. You need to get the car built, then to the track and makes adjustments from there.
    gnichols, rod1 and AHotRod like this.
  22. -Brent-
    -Brent-
    If you're serious about getting power out of the 292, I'd scratch that list you've got and look at what the big boys play with, aluminum heads, 4 barrel intake/carb, stroked, cam, etc. As well, 11s in the 1/4 likely means it'll be geared to be pretty high RPMs on the highway.
    This is from Mummert's page.
    I'm a fan of the y-block but after doing some homework I decided to jump ship and either run a 389 Pontiac or a 383 SBC (that's dressed like a 283 or 327).
  23. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    This guys no dummy, y block= boat anchor
    Montana1 and das858 like this.
  24. Flatblack 31
    Flatblack 31
    Halfway… Then you are heading out.
    Sent by homing pigeon
    seb fontana and BradinNC like this.
  25. enigma57
    enigma57
    FWIW, I built a Y-block in high school. Ran well. We had a '54 Ford and the block cracked in the winter of '64. Found a good 292 block. Put the short stroke '54 239 crank and rods in it along with a set of 0.040" over custom Jahns forged pistons with compression height set for 239 spec. Ran an Isky RPM-300 solid lifter cam (hotter than Isky E-4 cam). Also ran heads, intake and dual exhaust manifolds from a '57 312 engine and a 4100 Autolite carb from a 390 Ford. 4.11 gear and 3-speed overdive transmission. Drilled, tapped flywheel for '57 Ford cop car 11" clutch. She wouldn't rev quite like a 365 HP 327 Chevy, but the '54 was lighter than the '55 - '56 Fords and the destroked 292 would rev faster than most Y-blocks and would give just about anything other than a hemi a run for their money. If you can get better breathing aluminum heads and a better intake for the Y-blocks now of days, you should be able to get down the road pretty well in a light car like your Model A.
    600 cfm Holley double pumper should do it. Along with a magnetic pickup in your distributor, an MSD CD ignition box and a good hot coil. Best we had in the early '60s was dual point conversions and Mallory Voltmaster coils.
    I wouldn't trust a T-5 to hold together behind a 'built' Y-block if you run it hard and do what you need to in order for it to hook up, though. Contact D&D and see if they still have T-56 6-speeds for Ford applications in stock. And by all means, run a 9" Ford rear with good 31-spline axle shafts if you plan on running it hard.
    Can't say much for slush boxes. I'm an old stick shift guy. If you go automatic, just remember that an automatic tranny will weigh more and even if you stick with a stock converter, an automatic will take some horsepower to run in addition to losing at least 8% power through converter and internal slippage. More so if you run a loose converter.
    Don't worry about time slips. You're not building a race only car here. Just build her to run, build her strong and safe and have fun. Whatever times she runs when you take her to the strip a couple times each year to sort things out is whatever times she runs. If your goal is speed first and all else second...... Think hemi. 341 DeSoto or 354 Chrysler built to the hilt.
    Hope this gives you some ideas.
    Good luck with your project,
    Harry
  26. jakesbackyard
    jakesbackyard
    from ND
    1. Upholstery
    Weighed today...2540 lbs. Without me in it. About 6 gal of gas. All steel, 302, C4, 8" rear, Vintage air heat/ac.
    Blue One likes this.
  27. Larry T
    Larry T
    I think Don's calculations are rear wheel horsepower (maybe) might need to add a little to them for engine horsepower.
  28. Atwater Mike
    Atwater Mike
    @jakesbackyard has gotten the rare formula for Jack Chrisman's "Torrid '29 Tudor" down pat!
    First magazine car to drive me nuts in 1954... Beautiful car, Jake! Maybe more photos???
  29. jakesbackyard
    jakesbackyard
    from ND
    1. Upholstery
    Not a clone, but Chrismans was the inspiration.
    gnichols and Blue One like this.
  30. Bearing Burner
    Bearing Burner
    from W. MA
    You ask how much does a Hot Rod weigh? There many Model A roadsters which weigh over 5000 lbs and run over 200 Mph at Bonneville. All it takes is power to make a "brick fly".
    Montana1 likes this.
