TECH: Ultimate T-5 Article
Discussion in 'The Hokey Ass Message Board' started by Flat Ernie, Mar 25, 2007.
  1. [​IMG]
    Is this what your looking for? This is a t5 out of a s10.
    4.682 and 1.371
    Devonrod and loudbang like this.
  2. earlymopar
    earlymopar
    Flat Ernie: Are you aware of whether any of the long input shaft T-5s used behind V-8s in Mustangs?
    "The late-model (1994-95) 3.8 V6 T-5 was rated at 265lb/ft, had the slightly longer input shaft, and had the following ratios:"
    1st - 3.35 2nd - 1.93 3rd - 1.29 4th - 1.00 5th - 0.73
    Thanks,
    - EM
  3. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    Hey guys, Im looking for a adapter to put a t5 behind a 59a engine,
    Anyone know where I can find one, or if they even make one ?
    Thanks ...
  4. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    Also, I was wondering if I can run the non wc tail housing with the forward shifter on a wc unit ?
    I know theres some difference on the counter shaft oil damn, I think ?
    Thanks ...
  5. gimpyshotrods
    gimpyshotrods
    http://www.jalopyjournal.com/forum/threads/t5-tailshaft-swap-for-dummies-with-pictures.280529/
    http://www.wilcap.com/wilcapstore.html#!/BH-59A-350/p/54397304/category=14420225
  6. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
  7. There is a member whose user name is INLINE who makes and sells T-5 adapter plates for all kinds of applications. He has an ad in the parts for sale forum. I bought one from him, good quality, competitive price, and timely shipping.
  8. fenderhead
    fenderhead
    from Stevens PA
    Guys I need your help. I was reading this article and it mentioned a speedometer conversion. I have Stewart Warner mechanical gauges but my T5 has the electronic connection. Where can I get a converter so that I can use my existing gauge? I don't want electronic gauges. Hoping Flat Ernie has info. Any help would be appreciated. Thanks
  9. Kato Kings
    Kato Kings
    from Minnesota
    loudbang and gimpyshotrods like this.
  10. gimpyshotrods
    gimpyshotrods
    Fenderhead meet Kato Kings. Kato Kings meet Fenderhead.
    This place is a rod and custom skill set department store. We've got it all!
  11. Flat Ernie
    Flat Ernie
    Tech Editor
    Yes, the 94-95 V8 T5 has the longer input shaft as well. That info should be in the tech write-up. The SN95 platform required a longer/deeper bellhousing for 'packaging', so all T5, both V6 and V8, got the slightly longer input shaft. On the V8 cars, the input shafts between the '89-93 & '94-95 are interchangeable except for total length, so if you get a '94-95 and need the standard length, just swap the input.
  12. Mule Farmer
    Mule Farmer
    from Holland MI
  13. Devonrod
    Devonrod
    from london uk
    Thats great thanks for your kindness
    tudorfritz likes this.
  14. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    hey guys, i got a question, im running a t5 in my 50 and a tremec 6 speed in my 32, i have a habit of kinda pushing the shifter outta gear as im slowing down,
    you know, if you just put a " little " pressure on it, and when the rpm,s kinda line up she will slide in to neutral,
    think thats bad for it ?
  15. fatboys69
    fatboys69
    from Tennessee
    i am planning on running the spacer / adapter on my SBC/S10 T-5 . will i need to make a spacer for the hydraulic throw out bearing to function correctly ? my spacer moved the trans back 7/16" so the input shaft sould seat into the clutch disc and pilot bushing ok . Thanks in advance
  16. gimpyshotrods
    gimpyshotrods
    Unknown. I am not sure that this is a question that we can answer, without knowing exactly what hydraulic throwout bearing you are running, and exactly what bellhousing, and exactly what spacer.
  17. fatboys69
    fatboys69
    from Tennessee
    am running a Howe hydraulic unit and have an aluminum GM bell housing that I picked up from a buddy of mine.
    I made the spacer that goes between the bell housing and transmission here at my work ( we have a full machine shop). Spaces the trans 7/16" further back and was thinking it will need a spacer to make up that distance it moved back to get the throw out bearing to function correctly. Am I thinking correctly ?
  18. fatboys69
    fatboys69
    from Tennessee
    running an 11" clutch / pressure plate from an Astro van ( 4.3 v6 ) and large GM flywheel as well.
    It has the 14 spline need to work with the input shaft
  19. gimpyshotrods
    gimpyshotrods
    Does your spacer index the center register of the bellhousing on one side, and receive the input bearing collar on the other side, or is it just a flat plate?
  20. gimpyshotrods
    gimpyshotrods
    Oh, and is the one that is located off a single stud, or the one that bolts down to all four bolts of the input bearing collar?
  21. fatboys69
    fatboys69
    from Tennessee
    it is located off the single stud, havent made the spacer yet. just now starting re assembly.
    I assumed it needs to be like a collar and slide onto the shaft housing to space the bearing out from the transmission
    to keep all of the relationships between the bearing and fingers on the flex plate correct so it can function properly
  22. C Crews
    C Crews
    very good reading.i have a simple question. 4cyl s-10 5 spd, 283 chevy with stock 283 bellhousing and 60's vette lite factory flywheel. what clutch, pressure plate and throwout bearing do i use, or can i use the s-10 stuff ? the 283 is stock, so i figure the trans will last a while . thanks for all the great info on the t5.just want to know whats right for my application.
  23. C Crews
    C Crews
    please
    jchev1953 likes this.
  24. lowrd
    lowrd
    If you have not read this entire thread, do so. The information is there concerning engine/trans combinations guys are using in their rides. Also check inliner internationals tech section about which disc to use. I did not see where you live, but check with a clutch rebuilder about the disc. I would assume you would use a stock style pressure plate for the engine year/model. The disc hub can be replaced with whatever fits your input shaft.
  25. C Crews
    C Crews
  26. C Crews
    C Crews
    read the whole thread. i just thought someone might have part numbers i could use for clutch ,pp and throwout bearing. thanks
  27. loudbang
    Tim_with_a_T and Blues4U like this.
  28. Tim_with_a_T and loudbang like this.
  29. Trethewey
    Trethewey
    What is the thickness of the mounting ears on a GM Muncie-style T-5? I don't have one on hand and I'd like to go ahead and order mounting studs.
    Thanks, Eddie
  30. Bcap55
    Bcap55
    from PA, USA
    I have a 1983 T5 from a V8 Camaro with the Chevy bolt pattern, the mounting ears are .530 inches thick.
