Have rebuilt Mopar 440 Big Block engine and 727 transmission for sale. Engine and transmission came out of 76 Chrysler New Yorker. Engine and heads have been machined and rebuilt with some performance parts to make a hot street setup. 727 trans rebuilt as well. Did have a minor oil pan leak when pulled. Engine ran good when pulled. ~800 miles on engine. Had in my 99 Dodge Dakota. Made a fun, fast truck to drive! Also have engine and transmission mounts for engine/trans if wanting to put in Gen III Dakota as well or adapt to Dodge pilothouse truck using Dakota frame swap. Engine rebuild specs: Bored. 030 over Hughes Engines 2832BL camshaft Hyd flat tapper cam 228/232-110° lsa Lobe lift .353"/.357" Very hot daily driver, street/strip cam KB Performance flat top pistons Oversized valves 2.14" intake valves and 1.81" exhaust valves Edelbrock performer RPM intake Aluminum roller rockers, 1.5 ratio Stiffer vavle Springs Performance pushrods Magnetic performance distributor. MSD 8.5mm spark plug wires Dakota accessories with serpentine belt Alternator, power steering pump, according compressor. Head studs/nuts Custom Serpentine belt setup utilizing Dakota accessories. 727 transmission specs: Performance rebuild/shift kit ACC performance Boss hog "nightstalker" torque converter. I believe it's a 2200 RPM.
