I have a 35 ford truck that I am using the flathead, and the orignal rear end. I want to install a 5 speed from a s-10 . I have done this on f-1 ford trucks, but I do not want to hack up the original crossmember. I know I will have to go with a open drive conversion. Who has a lot or way of installing the trans without cutting up the frame? Thanks Sent from my iPhone using The H.A.M.B. mobile app
Cool truck ! A tape measure and a few minutes should answer the fitment question. Would let you know where the trans will rest and how much clearance issues you might have . Are those front fenders glass ? They just have a different look to them . Sent from the frozen North
No reason to "Cut up" the frame, we just finished a 35 Ford 4 door doing the same thing, just get the TCI kit and drill out the rivets on the factory x member and install the new one in its place no cutting, just getting rid of rivets and replacing with bolts.
If the TCI kit doesn't do it for you, consider the closed drive conversion of the Jeep T5. http://www.jalopyjournal.com/forum/threads/jeep-t5-torque-tube-adapter.1002913/#post-11607174 note that if you plan on keeping the rear wishbones, the TCI kit does not have a mounting point for the pivot
If you want the original center to your crossmember left in there, it ain't gonna work. The T5 has a big ol fin down the bottom of the tailhousing. Do some simple measuring and you'll find it will be into the same space the crossmember wants to be. Some guys have removed the top half of the crossmember, leaving the bottom portion though.
The chassis engineering cross member fits where the old one did, drill out rivets, and works great. Sent from my SM-G920V using The H.A.M.B. mobile app
Here's how some guys on the Ford Barn went about it, T5, torque tube, stock wishbone, etc. They did trim out part of the center. http://www.fordbarn.com/forum/showthread.php?t=206955&highlight=T5+TORQUE+TUBE
Thanks, yes the fenders are glass, the rest of the truck is all steel, a little rust and a draw small dents and no filler anywhere. I remembered the chassis engineering kit after posting. I will have to Make some tabs for the rear links to mount to which I have figured out. I looked at the jeep trans so I could retain the closed tube driveshaft and that is a option. I talked to the guy that builds the kit but you still have to come up with a adaptor to bolt the trans to the flatty. The t-5 is more available from s-10s and the conversion parts are available. Thanks for the info Sent from my iPhone using The H.A.M.B. mobile app
Did a 39 Ford with a Stroker Merc flattie and S-10 5 speed used the T.C.I. crossmember kit . Used a Granada rear and parallel spring kit . Worked slick and the customer was very happy.
This is exactly what we did minus the stroker, our customer wanted it original so we did a full rebuild on the 35 Flattie. Works fantastic, the car is just a blast to drive, handles the road with the factory suspension height like a dream.
