Hot Rods Jerry 's 32 5 Window Project
Discussion in 'The Hokey Ass Message Board' started by HomemadeHardtop57, Sep 7, 2016.
  1. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj and Stogy like this.
  2. Jerry & Andy, You both have all of us out here in cyber lands attention to the fullest. We like what you guys are putting together. It is always fun to watch two mad masters at work. This is going to be one bad ass hot rod. Jerry I am glad you went with your hand cut louvers as they just add total style to this build.
    Thanks for the ride along on this killer build.....Merry Christmas guys
    bowie likes this.
  3. bengeltiger
    bengeltiger
    Hand cut it is then! Awesome! I admire the commitment and love the look.
  4. HomemadeHardtop57
    HomemadeHardtop57
    If you can guess what this is and what I'm going to make with it you may win a prize lol . 1481916841725.jpg
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  5. brady1929
    brady1929
    Gas cap and sand cast. What do I win?
  6. fleetside66
    fleetside66
    I'm guessing a piece of embalming equipment & you'll use it as an oil filter canister cover.
    HomemadeHardtop57 likes this.
  7. trey32
    trey32
    Formaldehyde cannister, nice.
  8. HomemadeHardtop57
    HomemadeHardtop57
    Steering box mount just about finished up. There's adjustment built into the mount to position the box so the steering can be dialed in. Also it can be adjusted up or down to compensate for seat position. Fully adjustable but rock solid when locked down.
    I'm going to have to lengthen the shaft that attaches to the wheel about 6 inches.
    1481944518190.jpg 1481944528737.jpg 1481944545887.jpg 1481944560031.jpg 1481944567487.jpg 1481944573317.jpg 1481944581527.jpg 1481944586847.jpg 1481944593147.jpg
    lothiandon1940, loudbang and Stogy like this.
  9. HomemadeHardtop57
    HomemadeHardtop57
    ls1yj, lothiandon1940 and Stogy like this.
  10. HomemadeHardtop57
    HomemadeHardtop57
  11. HomemadeHardtop57
    HomemadeHardtop57
    Because the car is going to sit very low, we decided on mounting the rear wishbone end inside the frame on the rear rather than on the end of the axle in the stock location. This gives some more clearance
  12. HomemadeHardtop57
    HomemadeHardtop57
  13. HomemadeHardtop57
    HomemadeHardtop57
    Here's something cool that Andy came up with that I thought was super clever for the lower shock mounts on the rear.
    The lower mount is part of a front wishbone yoke. The recess where the spring perch would normally fit into is the perfect size for a shock stud. One half of the yoke was cut off then welded to the rear.
    On the backside of the new lower mount the bottom part of an F-1 shock mount was cut off and used to mount the rear bones. You still with me?? Haha
    Front half ...wishbone yoke for lower shock mounts
    Back half-..mount for rear bones ends made from F-1 shock mount bottom that was cut off.
    Front half and back half welded together then welded to rear.
    In the pics these are just tacked together right now but you get the idea.
  14. HomemadeHardtop57
    HomemadeHardtop57
  15. HomemadeHardtop57
    HomemadeHardtop57
  16. DDDenny
    Cowl steering pass through estruchean.
  17. HomemadeHardtop57
    HomemadeHardtop57
    kidcampbell71 and Stogy like this.
  18. HomemadeHardtop57
    HomemadeHardtop57
    Tomorrow I'll be louvering the top insert that I made and the decklid skin. I got the decklid skin sanded down and started the layout. For laying out my centerlines on decklid skins I use a bent piece of 1/8 inch flat stock that I shaped to match the crown.
  19. HomemadeHardtop57
    HomemadeHardtop57
    Got the inset louvered today. I still need to dress the edges with a file but I was tired and called it a day.
    First I cut my lines. Hit the top with a DA sander, then smacked the louvers in with my fixture and a 5 lb sledge hammer. I'll post some pics of the louver setup.
    ct1932ford, Hamtown Al, ls1yj and 8 others like this.
  20. HomemadeHardtop57
    HomemadeHardtop57
    The louver dies were made from the end of an early Ford torque tube. How's that for traditional. Haha. The pieces were trimmed and welded into a simple handheld fixture. I cut the 3 inch line, lower skin down over the 3 inch sheet metal guide, line the top part of the fixture up with the guide plate then go. I hit it light about 5 times to knock the metal into the lower die and seat the male die then give it hell about 5 more times.
    After the first two rows you basically get the shits of it and want to go watch TV or drink a beer. I guess if it was easy everyone would be doing it. Ha
    ls1yj, 31Truckster, slv63 and 10 others like this.
  21. DDDenny
    Wow, that's looks good, mad skills and patience Jerry, you gotta want it pretty bad considering the extra effort required for that "back in the day" look.
    Now I wish I hadn't commented on your hood plans cuz I know whatever you do it will come out nice.
    31Truckster and lothiandon1940 like this.
  22. bengeltiger
    bengeltiger
    Louvers look great. Thanks for sharing your setup!
  23. Hendee
    Hendee
    Great looking louvers, and thanks again for sharing your setup. Finished product looks great, and seeing the tools that get your there is an added bonus.
    Tom
    Stogy likes this.
  24. HomemadeHardtop57
    HomemadeHardtop57
    Sure no problem. I think it's a pretty neat tool and wanted to share
  25. HomemadeHardtop57
    HomemadeHardtop57
  26. '52 F-3
    '52 F-3
    very very nice, thanks for sharing your process and pictures. (note to self... copy this excellent idea)
  27. bengeltiger
    bengeltiger
    There's a Homemade Tools thread where I bet a lot of guys would love to see this, too. I've seen other, less repeatable setups and think yours would provide better, more consistent results.
  28. continentaljohn
    continentaljohn
    Awesome thread and love the louvers idea! I have to ask about how you cut the slots plasma or cut off wheel , looks super clean and awesome job!
  29. HomemadeHardtop57
    HomemadeHardtop57
    Cutoff wheel and lots of patience.
    Stogy likes this.
  30. HomemadeHardtop57
    HomemadeHardtop57
