Technical 3100 bumper lowering
Discussion in 'Traditional Hot Rods' started by 55zephyr, Nov 27, 2016.
  1. 55zephyr
    55zephyr
    Hi all, has anyone lowered the front bumper on a Chevy 3100 truck ? If so how and how much?
    Any pictures would help greatly.
    Cheers, Ron.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Why? Is this a custom?
    Can't imagine how this can look good.
  3. 55zephyr
    55zephyr
    No, I'm lowering the whole truck keeping the original frame and suspension and have heard that lowering the bumper a touch helps with the look.
    Cheers, Ron.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Have you considered tucking the bumper closer to the body and modifying or eliminating the gravel guard?
    mgtstumpy and iwanaflattie like this.
  5. ...you're lowering the whole truck but can't figure out how to lower the bumper?
  6. squirrel
    Z the brackets?
  7. Schwanke Engines
    Schwanke Engines
    The front bumper is already about 2" lower than the front fenders stock, we usually have clearance issues when we slam them because the bumper is so low.
    Sent from my XT1585 using The H.A.M.B. mobile app
  8. Id bag the bumper :).
  9. 55zephyr
    55zephyr
    Thanks for your replies, the bumper is staying where it is, the truck is going as low as I can get it on the stock frame. Job done.
    Cheers, Ron.
  10. Well.......That was easy! :D
  11. jvpolvere1
    jvpolvere1
    Ron, don't get discouraged. You get a lot of good advice and "straight talk" on the HAMB.
    Ask away, mate.
    Sent from my SM-T377V using The H.A.M.B. mobile app
  12. jvpolvere1
    jvpolvere1
  13. 55zephyr
    55zephyr
    Thanks mate, I like to think I can rise above sarcasm.
    Good luck, Ron.
  14. Flamed48
    Flamed48
    As a fellow 3100 owner the bumper looks fine in the stock location when you lower it, on my truck I've got a 79 Camaro clip and with the front being so low all my grandpa did was trim it so it wouldn't drag or scraping going in an out drive ways
  15. saltflats
    saltflats
    from Missouri
    The one on the right was just moved in and new panels made to fill in the gap. 20160318_140059 (1).jpg
  16. 55zephyr
    55zephyr
    Thanks saltflats, that's a super fine looking truck, same colour as mine too. The original panel is out of shape so that seems to be the way to go, does look neater.
    Cheers, Ron.
  17. saltflats
    saltflats
    from Missouri
    When I moved this bumper back I just made two separate filler panels.
