Correct made a frame first then just covered it for looks Sent from my SAMSUNG-SM-G870A using The H.A.M.B. mobile app
Nice work bennie! Have a weakness for following a builds... Sent from my iPhone using The H.A.M.B. mobile app
had to make my own these things suck nothing lines up Sent from my SAMSUNG-SM-G870A using The H.A.M.B. mobile app
Yes I did made a jig and heated the metal into the shape I needed Sent from my SAMSUNG-SM-G870A using The H.A.M.B. mobile app
Sounds like an interesting process. More than likely above my skillset, but would like so see how it works and the result.
she's on the ground again tomorrow going to replace back tires to bigger ones Sent from my SAMSUNG-SM-G870A using The H.A.M.B. mobile app
I like it! Tried 36 headlights on my AV8, but the tires hit , so I changed them. I see you've mounted them to avoid that. Sent from my iPhone using The H.A.M.B. mobile app
Great work, floors are awesome ! One question about the panel below the trunk lid, is the lip above that panel which meets the lid when closed a repo piece or did you fabricate it ? I'm converting from rumble to lid and not sure how it comes together. Thanks, Sent from my iPhone using The H.A.M.B. mobile app
Pretty sure the inner panel creates the lip for the trunk to close against. http://www.macsautoparts.com/store/...upe-with-trunk.html/?crosssell=Product_Viewed
