Projects Swapping rear ends
Discussion in 'Traditional Customs' started by 54monarch, Sep 21, 2016.
  1. 54monarch
    54monarch
    from Calgary
    Hi Guys,
    I am trying to identify the rear end in my Monarch. It was swapped out. I was convinced it was an 8.8 but on a further look I believe it is a 8.7 WER out of a Granada. [​IMG] [​IMG] I have an 8 inch out of a 65 Mustang that I can put in but it will need a few mods. Is it worth the time. I would like to put discs on the back one day so I am leaning towards junking the 8.7 if that is truly what this is. 20160921_094233.jpg
  2. Mr48chev
  3. The WER rear is pretty rare, used ONLY in Some 75-78 Granada's and Monarch's.
    The only way I know of to tell the difference if the tag is missing is to pull the cover and see if it has shims on the side of the carrier bearings or screw in adjusters like a 9". Shims = 8.8, adjusters = 8.7 WER
  4. onetrickpony
    onetrickpony
    from Texas
    Yes, it looks like a WER. Here is a pic of a WER cover gasket:
  5. Mr48chev
  6. squirrel
    the 8.8 cover is almost square, so I doubt it's an 8.8
    Ford 8.8
    Ford 8.7 WER
  8. mgtstumpy
    mgtstumpy
    My 8.8 has those 2 x lower notches in the casting as per above gasket. Yep 8.7 as that rear end isn't as deep as an 8.8
  9. aaggie
    aaggie
    Since your desire is rear disc brakes why not just get an Explorer rear complete with the discs and swap it in now? Probably a lot of them available even in Canada.
    falcongeorge likes this.
  10. BJR
    BJR
    What does "WER" stand for?
  11. squirrel
    BJR likes this.
  12. Bounder
    Bounder
    I put a explorer 8.8 in my merc. Fits and works great, has disc and limited slip. Out of a 2001 explorer. Only problem is trying to change the gear ratio. can't find higher ratio like a 3.08, now I have a 3.73 I'm turning 3000 rpm at 60 and that ain't working for cruising.
  13. squirrel
    I had a 93 crown vic with a 8.8 rear that had 3.08 gears in it. Shouldn't be that hard to find the gears you want. they used the rear for a long time in lots of different applications.
  14. Bounder
    Bounder
    Maybe I'm just not looking in the right places, seems I can find lower ratios but not the higher. Then again I haven't looked that hard. Trying to get interior and air in the ole Merc.
  15. squirrel
  16. blue 49
    blue 49
    from Iowa
    I have a Ranger 8.8 with 3.08's, too.
    Gary
  17. Bounder
    Bounder
    Dang Squirrel I always knew you were good. I'll just have to get on evil-bay and buy that bad boy.
  18. squirrel
    you don't have to buy it on my account, I just wanted to show you how easy it is to find stuff if you look around.
    make sure it will fit your rear, I don't know anything about interchangeability on those rearend. I know other brands have different differential carriers for different ratio ranges, so you might want to investigate before you get too far.
  19. Bounder
    Bounder
    Yeah that may be a problem since it's out of a mustang and mine is out of an exploder. I'm not really up on fords as much as gm products. I've been told they are a pain to build. Just always wanted a 50 merc. Haven't really done much in years til I bought the merc a 8 years ago. Gotta find a ford guru here in town and just ask some questions.
    Thank you for responding and being helpful, as always. Some folks on here want to be smart alecks.
  20. 1-SHOT
    1-SHOT
    from Denton
    Try your local Ford dealer and look up some part numbers for R/P and carriers that should give you a answer.
  21. All of the 8.8 gears fit ANY Ford 8.8 carrier. Doesn't matter if it locker or not, 28 or 31 spline etc.
    squirrel likes this.
  22. falcongeorge
    falcongeorge
    from BC
    Not sure if this is what you are thinking, but if your expectation is to find an EXPLORER rear with 3.08's in it straight from the factory, you wont. You will have to swap the ring and pinion.
  23. Explorer 8.8's came with 3.27, 3.55, 3.73 and 4.10
  24. squirrel
    Thanks for the help, good to know that the 8.8 gears are all interchangeable. Kind of like Ford did with the 9", makes life easy
  25. 1-SHOT
    1-SHOT
    from Denton
    Thanks for the info.
  26. Bounder
    Bounder
    I got the whole 3rd member out of a 2001 exploder and it was 3.73 with disc barker and limited slip. happy with it just geared too low.
    Thanks to everyone for the information, it did help.
  27. falcongeorge
    falcongeorge
    from BC
    FWIW, I think the majority of 5.0L mustangs left the factory with 3.08s, and TONS of guys swapped them for 3.73's or 4.11s, so used 3.08s for an 8.8 should be REALLY easy to find.
  28. JeffB2
    JeffB2
    from Phoenix,AZ
    Now if you had overdrive you could keep the 3:73's and be happy.
  29. Bounder
    Bounder
    Yeah thought about a AOD but not let.
  30. JeffB2
    JeffB2
    from Phoenix,AZ
    Best AOD to look for is 1989-93 these have the latest lubrication upgrades and improved valve body and are non-computer just add the Lokar cable kit.
