Features HAMB Shoebox Club
Discussion in 'The Hokey Ass Message Board' started by Chopped50Ford, Dec 3, 2006.
  1. manyolcars
    manyolcars
    Consider putting that mirror on the dash, maybe a dome lite would cover the old holes
  2. Kiwi 4d
    Kiwi 4d
    Good thought. thanks the dome light would do it.
  3. 50Fraud
    50Fraud
    My '51 Victoria has its rear view mounted to the center divider, about halfway from top to bottom. It's the stock arrangement for a Vic. I don't imagine that Ford sold Victorias in NZ, but you could probably get the necessary stock parts from a shoebox specialist like the guy in OK. Or not.
  4. Hogger
    Hogger
    from Carvel AB
  5. frosty-49
    frosty-49
    MO_JUNK, dwollam and Icufltrn like this.
  6. jhammer
    jhammer
    I'm in, but I have a lot of work to do[​IMG][​IMG]
    MO_JUNK and RebelAlliance like this.
  7. nice score jhammer
  8. jhammer
    jhammer
    Thanks, I picked it up a couple of months ago. So far I have rebuild the ends of the hinge pillars, and put in the driver and passenger side floor supports. I'll be installing the new rocker panels next, then the floors
  9. willumbilt
    willumbilt
  10. willumbilt
    willumbilt
    Old-Soul likes this.
  11. willumbilt
    willumbilt
  12. manyolcars
    manyolcars
    I've made a little progress with my Crestliner. I drive it frequently crestlinerskirts.jpg
  13. a11drewp
    a11drewp
  14. I will bite I drug this rust free one home trying to sell the Jamco front end kit and rear kit so I can build it to lay frame got a nice Y Block and 3sp od trans 3x2 intake
  15. low50s
    low50s
    Hey everyone just visiting this thread again my shoebox has been in storage for a few years and man I am getting the urge to get back at it !!
    About 6 years ago I installed Fatman fab subframe under the front but I think I want to go back to factory front end parts so I may end up hunting for a good frame
    daddio211 likes this.
  16. Rathbone
    Rathbone
    Why would you go back to factory?
    Jugornot and chopper99 like this.
  17. low50s
    low50s
    I want to go back to flathead, it says you can't use flathead with Fatman fab subframe.
    Plus I feel it will be easier for me to get body mounted along with radiator and such
    I have had subframe installed for some time and I still have not bought all my control arms and spindles to get it movable
  18. Scottie32
    Scottie32
    from MPLS, MN
    My '49...351W/C6 re-powered. Bought in June '16 and got it running by October all DIY/lone-wolf style.
    MO_JUNK likes this.
  19. P1020502.JPG I'm in, sign me up.
    Just kinda getting started though.
    consider this a "before" shot.
    MO_JUNK, dwollam, Cooon and 1 other person like this.
  20. TS057
    TS057
    from Fargo, ND
    1. shoe box hambers
    Nice '50 coupe! Looks like a great starting point. That Fulton visor is worth ~$500 on ePay if you're not going to use it. I sold mine and was surprised by the amt of money it brought. I was also surprised by the amt of fees they charged and wish I'd just sold it here on the HAMB. Lesson learned. Good luck w/ the project!
  21. Duck's Goat
    Duck's Goat
    Here's mine, had it for a few years now. I lowered it with cut springs in the front, blocks in the back. Rebuild the original rear end, overdrive transmission, and built a stroker flatty. I don't get to drive it much due to the girlfriend taking it over, but I think its pretty cool to have a girlfriend that loves to drive a 3 speed on the column.
    MO_JUNK and Ron Funkhouser like this.
  22. joeoldsrocket
    joeoldsrocket
    Whats up guys. Just have a question . Have anyone used the 54 chevy grillteeth on the original 51 ford grill bar. Thanks for the help.
  23. John M
    John M
    [QUOTE="Whats up guys. Just have a question . Have anyone used the 54 chevy grillteeth on the original 51 ford grill bar. Thanks for the help. [/QUOTE]
    54 Chevy Grill bar3.jpg 54 Chevy Grill bar with 9 teeth HAMB Shoebox Grilles.jpg Lakewood  50 LF-HAMB 8648345.jpg
    I'm not sure but I don't think the profile of the 51 grill bar is the same as the notched area in the Chevy teeth. You would have to shape the teeth openings to fit as long as they weren't too big in some areas already. Also you would have to drill holes to mount the teeth. Chevy bars are pretty reasonable but you have to use two to span the opening of the 51 between the corner pieces above the turn signals. One bar has to be split, then used on each side of the other bar. 54 Chevy Grill bar3.jpg 54 Chevy Grill bar with 9 teeth HAMB Shoebox Grilles.jpg Lakewood  50 LF-HAMB 8648345.jpg
    MO_JUNK, dwollam and Ron Funkhouser like this.
  24. Bertolasi
    Bertolasi
    [​IMG] The 50 Ford in the pictures is the one that i now own. Bought it from HAMB member in Lakewood Washington. I am under the impression that the grille mods were made before he bought the car but I did take some pictures when I was taking all apart for the changeover to Flashback 50 (project is on HAMB). Here are a couple of images that might help explain what was done to make this one 'work'. Regards, bob
  25. joeoldsrocket
    joeoldsrocket
  26. joeoldsrocket
    joeoldsrocket
    I have the 54 bar grill but now i see i need 2. Thanks again for the tips
  27. 32coop
    32coop
    from Australia
    1BA6FBD4-6B60-479A-82CE-73F98A874163.JPG I'm in I just dragged this one home for the wife. Just gunna get it on the road with the flat 6 before anything major gets done.
    MO_JUNK likes this.
  28. Toddjg
    Toddjg
    from florida
    I'm installing a sbc into my '50 shoebox can anyone tell me what long tube headers fit best brand model
  29. Last edited: Jan 25, 2017
  30. Bertolasi
    Bertolasi
    I have an sbc in our 50 Ford Flashback project but am not sure the the Hooker headers we have are what you are asking about. By long tube do you mean individually laid parallel stack with no muffler? We have 3 inch collector transition to 2 1/4 inch exhaust with Hush Power mufflers. If you are interested in that be glad to provide some details. bob
