A (dumb) upholstery question. What is the proper name of the cardboard material used for interior panels? Thanks
Guy used PVC panels instead of cardboard on my car. Said it wouldnt warp like the cardboard. Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
Waterproof panel board. http://midwestfabrics.com/upholstery-supplies/large-water-proof-panel-board.html
The black cardboardy stuff in large sheets is car panelboard. The thin stuff in small sheets is furniture panelboard. You want the black waterproof .10" thick kind for car door panels. Don't forget to put plastic between the door and door panel or the damp will warp it.
Sid Chavers uses Luan plywood, illustrated on his tapes. My mother in law, Joyce watched the door panel tape, (she's an A-1 upholsterer and seamstress) Joyce said she learned 3 new methods right off the bat! I was impressed with Sid's method of clear plastic for a pattern. Set it up, look right through it for the attaching holes, mark with a Sharpie... The Luan ply works excellent, it holds its 'flatness', but if necessary can be wetted and shaped with water and a heat gun. Permanent. Glue to it, staple to it.
The trade name on the Polly sheeting is " Centra", 1/8" works well for interior backing. It's also waterproof and heat formable. .......... Jack
http://www.midlandplastics.com/locations.htm Midland Plastics sells PVC board Sintra or Komatex, cheapest prices I've found but they are local pick up for me.
I uses 1/8 " ABS plastic panel board, it can be sanded, drilled, cut with a sharp knife and bent with a heat gun and is not affected by moisture. I think it was the perfect answer for upholstery backing.
I used PCV Sheets for the door panels in my convertible. I love it never warp, water won't affect it.
