bought a set of 16's mopar steel wheels from the 40s to 50s from a fellow hamber .4inches wide in process of ordering the proper tires .Thse wheels are set up to run hub caps I been told 40 ford will work . There going on my fender less 28 coupe .I dont think i want to run beauty rings . Give me your opinion on what hub caps you guys would run . All advice is appreciated
the first thing i would do was find out if `40 Ford caps actually fit on them...then you could run any cap from `40-`48 if they do
I know my '40 Chrysler caps fit onto '54 DeSoto wheels (with the clips) so I would think any 40-54 Mopar cap would fit. Full wheel covers in a 16" diameter are very hard to find.
I used 32 V8 caps on smoothie steel wheels without beauty rings on my build. I like simple and clean. Rather people walk up and see entire car instead of looking a one particular thing. Bought an adapter from wheel company to adapt 5 1/2 (or something close to that) caps to normal 15" rims. Pics in my media.
You'd have to piece together a whole set, but I think these caps are awesome. Made by National (of Hollywood flipper fame) but they didn't want to pay licensing for them to say Plymouth so they basically say huhuhuh on them, check this one out. http://www.ebay.com/itm/Antique-NOS...ash=item4afd93f31e:g:tEIAAOSw-YBXF--H&vxp=mtr I've seen them before so they can't be super rare. Would be a real unique detail and should fit directly onto your wheels.
Those are awes Squablow those are awesome i would run those . I might have to start collecting i went and measured they should fit .
It's not the first one I've seen, I bet if you search around for a while you could make up a whole set. You'll probably find them one at a time, since they were made as cheapie replacements for stock caps and not generally marketed as sets like the custom caps.
I bid on the one on ebay so will see what happens .I definitely think its something cool and different .
my family is from dayton ohio my dad was born there but grandparents moved to california in 58 when my dad was 6 months old .
302 AOD hit the Ford pickups did this too and with the adapter rings used 55-56 Ford Fairlane 15". That would be cool.
