Technical Langdon's Carter Weber Carbs??
Discussion in 'The Hokey Ass Message Board' started by fleet_47, Apr 23, 2016.
  1. fleet_47
    fleet_47
    from N/A
    Hey guys,
    Are they Carters? Or are they Webers?
    Anyone have the info on the 2-barrel carbs that Langdon sells called "Carter Weber".
  2. chriseakin
    chriseakin
    Probably similar to Holley Webers but can't swear to it.
  3. fleet_47
    fleet_47
    from N/A
    So "Holley Webers"? Does that mean Holley or in this case Carter was licensed to use Weber carb designs??
  4. They have the Weber casting "W" on the side and both the Carter stamped in model number and the cast in Weber numbers.
  5. statesblue
    statesblue
    from Luzerne Pa
    Don't know if their Carters, Webers or Holley's. I have them on my 63 and they work great.
    fleet_47 likes this.
  6. fleet_47
    fleet_47
    from N/A
    I hear ya! I plan to run them also, all I hear is good about them. I already placed my order but I'm just looking for a little background info on them. I already had someone ask me "carter webers? Are they Carters or are they Webers?" Hmm... Apparently a good question.
  7. fleet_47
    fleet_47
    from N/A
    Interesting, hence the name "Carter Webers". Thanks for the info
  8. Rusty O'Toole
    Rusty O'Toole
    The original design was Weber's, an Italian company. When Ford and Chev wanted to use them on their Pintos and Vegas in the 70s they had them made under license by Holley and Carter because it was cheaper.
  9. fleet_47
    fleet_47
    from N/A
    Good info, thanks!
