Projects Tucks 29 Roadster Build ---->
Discussion in 'Traditional Hot Rods' started by Tuck, Aug 26, 2013.
  1. falcongeorge
    falcongeorge
    from BC
    Tuck, if you find two more, those ET's are EXACTLY what I have been seeking for the front of my t-bucket...hint, hint, hint...
    Outback likes this.
  2. gnichols
    gnichols
    from Tampa, FL
    I haven't seen your thread in awhile... and your treatment of the A pillars and raising / flaring in the front of the doors is fantastic. Now, you don't have to call me copy cat, but that's a nifty little trick I'd like to duplicate some day. New pix coming soon? Gary
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    My deadline to have this rolling with the Hemi in it is June 25th.
    Mark your calendar if you're in Minnesota as I'm hosting a SWAP MEET that weekend too. (there is a car show too that the local club puts on) Its called the "Stewards Swap" - It'll be that Saturday June 25th starting at 7am. The fee for the swap is a donation of non perishable food items for our local food shelf. There will be beer and food vendors along with fireworks after dark. You must bring at least 80 percent car related stuff to sell. BTW we have a A&W drive in!
    I've been slowly plugging away at my frame... On top of college classes and teaching combined with family there is not much time left over... but I feel inspired to check in.
    I'm getting pretty excited to see this on all fours again. I've been coming in for a half hour to an hour whatever I get after school to weld for a little bit and then I head home. I've been trying to get the chassis welded up and all of the hundred plus holes filled. I've been tigging them shut with a copper backer and big filler rod. The big holes I make a plug and fill it. I just burn them close with a flap disk and then finish flush with a roloc and then I'll D/A them.
    I test fit the front and put some pressure on the spring so that I could get an idea of where the bone mounts might end up.
    The frame sure stiffened up with the X-member installed.
    The next big step is the rear end.
    I just bought a beautiful pair of Buick drums for the rear. I'm going to re-drill the rear bolt pattern on the olds rear to small bolt ford to match my mags... along with re-drilling the drums to the same pattern. I'm going to adapt Lincoln zephyr backing plates to the olds rear and make brackets to hang the 36 bones on it.
    This is an old pic from my album but you get the idea of how the rear end will look- the bones will mount in the center of the X right at the U-joint
    Can't wait to setup the rear end!
    Rolling Chassis, Rolling Chassis!!
    Tuck
    Outback, 31chevymike, putz and 8 others like this.
  4. Reply to a text message on occasion, would ya??? :D Lookin good bud!
  5. NoSurf
    NoSurf
    Looks great brother!
  6. Nads
    Nads
    from Hypocrisy
    Hey Jay, not to hijack this thread, but I bought that 1955 Zephyr Zodiac off of craigslist, Thank you.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Tuck, I want a swap space.....
    Outback and russellmn like this.
  8. Not to hijack this thread.... But where the hell have you been?
    Hey Tuck... Thanks for the progress report. Curious about the rear end setup...
    Sent from my LG-LS980 using H.A.M.B. mobile app
  9. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Converting an OLDS rear to 12" Lincoln brakes.
    I'm using actual rear Lincoln backing plates just used the wilsons for mock up. Made rings out of 12g to locate the ford backing plates on the olds axle then I'll use centering punch to locate axle housing holes and drill.
    Drilling the axles and drums to 4.5" b/c tomorrow!!
    Mags are at the machine shop- should have... Could have... It rolling on all fours by Saturday! (-;
  10. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Rear axle shafts now 4.5 b/c
  11. alchemy
    alchemy
    Why'd you weld up the old holes in the axle flange? Should it be trued now to make sure the face is flat?
  12. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Because I drilled holes for the new bolt pattern where those holes were and a file is good enough.
    @alchemy
    I used a 1/2" copper backer and did not weld them all at once- I'm pretty confident I don't have any warpage that I would warrant a lathe. If I'm wrong I'll report back.
    31chevymike likes this.
  13. speedaddict
    speedaddict
    from Austin, Tx
    Nice work Tuck
    Tuck likes this.
  14. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I had to get a shouldered stud to locate the drum- they only had three at napa rest will be here tomorrow! Stoked! Getting mags back tomorrow too- so I'll be cleaning those up and mounting tires!
  15. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I didn't weld up the old holes just the socket hole and the balance holes- if I did that much welding I probably would true them up- @alchemy
  16. titus
    titus
    are you gonna make a spacer ring for the drum to center on the axle hub? I just would trust the studs centering it. concentricity is out friend!
    it all a looking good, we might be putting Buick drums on the back of Ryan's 3 window but not sure yet
    jeff
  17. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I could easy enough! Didn't think of that- good idea- I'll cut one on the lathe-
    If you do decide to do it I'll have Bryan drop off some rings for the backing plates- @titus I had a few made up. I'm doing this same thing on my coupe.
  18. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Today is a good day...
  19. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Outback, 31chevymike, brad2v and 4 others like this.
  20. speedaddict
    speedaddict
    from Austin, Tx
    Something about guys and their wheels. Always makes us feel better looking at any of our projects with nice wheels and tires.
    Tuck and kidcampbell71 like this.
  21. Ugh! Those slicks though!!
    Tuck likes this.
  22. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    I totally destroyed my shop... HaHa- as @Moriarity and Roth would say- #bigmessbigsuccess
  23. Runnin shine
    Runnin shine
    Can't wait for a pic with the destroyer in there too.
    Tuck likes this.
  24. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Centering rings a success heated and slipped them on!
    31chevymike, Drewfus and falcongeorge like this.
  25. partsdawg
    partsdawg
    from Minnesota
    Have a pair of 14" Hollywood wheels if that size would work for you.
    One more thing...I will be vending at the swap if there are still spaces available.
    Tuck likes this.
  26. lodaddyo
    lodaddyo
    Looking good!
    Tuck likes this.
  27. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Getting the rear backing plates ready- still a lot of work to do but here is some progress!
    I used a strip of steel and ran it though the slip roll and then formed it over this form so it matched the outer diameter. I used silicon bronze to fill the deep pitting on the face.
    Some backing plate restoration- this one side was laying in the dirt and after it went through the cabinet it was a little rough- I got the front and back Lincoln brakes off the same zephyr.
    Trying to save it- there is still a lot of sanding to do to make these chrome worthy.
    Added the centering rings and welded the old holes shut- I'll clamp this in place and use centering punches to locate the new holes on the olds rear!
    Tuck
    Outback, Stogy, 31chevymike and 4 others like this.
  28. I don't have anything constructive to ad, besides it's looking fucking great!
    Outback and Tuck like this.
  29. Go man go! Wheels and tires look great!
    Tuck likes this.
  30. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    Redrilled for the olds rear- check!
    Outback and 31chevymike like this.
