Features New Model A coupe project.
Discussion in 'Traditional Hot Rods' started by skratch, Feb 10, 2016.
  1. waxhead
    waxhead
    from West Oz
    Off to a nice start. Looking good so far.
  2. Appletree
    Appletree
    from Houston
    Nice fabbing! Keep up the good work.
  3. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    Yeah, it helps having a youngun around to do stuff. I have 300lbs of bolts that need to be sorted that has me wishing I had a kid running around!
    What kind of dimpling setup did you use?
  4. Hammertime
    Hammertime
    Way cool Scratch !
  5. mike bowling
    mike bowling
    Nice start- red paint must have been on sale! My old coupe was painted the same way (red too- same guy?), but had NO prep done, and the paint was peeling off in sheets when I got it.
    Lookin' GOOD!
  6. oj
    oj
    They must've had a little paint left over from doing some barns.
    You're lookin good, I like the engine. Very nice.
    skratch likes this.
  7. Black Clover Custom
    Black Clover Custom
    Man i'm seriously gettin' the bug for a model a!!!
    You guys on here are like a good "model a" bar tenders... "you want another?" Hell yes...
    mike bowling likes this.
  8. mike bowling
    mike bowling
    Always room for one more. The "A" is the way, Brother! They made enough so we can all have a couple.
  9. U-235
    U-235
    very nice ......love the Hot Rod Lincoln theme......one question.....where are you going to put the foot feed...?
    rotenjon likes this.
  10. skratch
    skratch
    The pedal ? There's plenty of room in the car. I put them on the trans hump normally.
  11. skratch
    skratch
    ImageUploadedByH.A.M.B.1456365795.697015.jpg ImageUploadedByH.A.M.B.1456365847.186867.jpg
    49 Lincoln dash cut down to fit. Found a 50 ford column to thrown in the mix
    bct and kidcampbell71 like this.
  12. This is gonna be good!
  13. Binger
    Binger
    from wyoming
    Great looking start. Like the Lincoln engine.
  14. chriseakin
    chriseakin
    That dash looks really good in there. Just curious, how heavy is the floor framing there - what thickness metal is it?
    Looks like the floor is going under the framing?
  15. skratch
    skratch
    It's box tubing the same pattern as the car frame with 11 gauge sandwiched and welded , between the car frame and the floor structure. It makes the body very stiff.
  16. Like the way you let the firewall out on the top, cleaned up, it looks like it was always there!
    Looking forward to your thread.
  17. kingpins
    kingpins
    looks good skratch!
  18. barrnone50
    barrnone50
    from texas
  19. skratch
    skratch
    No. It was a 46 dodge truck I put Scotts hot rod suspension all the way around and installed a cad mill.
  20. skratch
    skratch
    ImageUploadedByH.A.M.B.1456962416.614511.jpg ImageUploadedByH.A.M.B.1456962461.610748.jpg ImageUploadedByH.A.M.B.1456962483.430055.jpg ImageUploadedByH.A.M.B.1456962541.853755.jpg
    Here's the new Rodsville quick change ( I had Logan Davis assemble for me ) with 36 bells and trailing arms , ford juice brakes.
    Looks great fully assembled and painted.
  21. looks great...really like the dash choice and the column....will be following along for sure
    falcongeorge likes this.
  22. Interesting build to follow; really like the details, especially the dash. Out of curiosity; I was wondering why you used front brakes (no E-brake) on the quick-change?
  23. S.F.
    S.F.
    Well this explains everything...
  24. Incredible fab work, nice!!
    skratch likes this.
  25. skratch
    skratch
    Those were rears. I welded up the holes for looks of course.
    I'm running a B&M hydro no need for an e brake
  26. skratch
    skratch
    ImageUploadedByH.A.M.B.1457022880.339999.jpg ImageUploadedByH.A.M.B.1457022921.212442.jpg
    Split wish bone and 36 trailing arms
    kidcampbell71 and RICH B like this.
  27. Holey mackerel! that is a lot of holes.....looks slick man
    skratch likes this.
  28. barrnone50
    barrnone50
    from texas
    skratch likes this.
  29. For a minute I though you used a wheelbarrow for a firewall like Frank did on the 51 Plymouth. Looking good man!!
  30. Very nice work indeed! :)
