Projects Wire wheel id
Discussion in 'The Hokey Ass Message Board' started by lodaddyo, Nov 9, 2015.
  1. lodaddyo
    lodaddyo
    Anybody know what this wheel came of of?
    16" with a 5 on 5.5 bolt circle. Its got a pentagon shaped center hub
    ImageUploadedByH.A.M.B.1447127423.521178.jpg ImageUploadedByH.A.M.B.1447127442.362384.jpg
  2. The spokes are welded, so NOT a Chrysler product wheel.
  3. Does the center look cut that way?Are you sure it's 5 on 5.5 not 5 on6?
  4. lodaddyo
    lodaddyo
    The center is stamped. And its 5 on 5.5, i measured with a bolt pattern tool
  5. Strange one indeed.
  6. verde742
    verde742
    looks home made,,,
    'member those days..
    how many ya got?
  7. lodaddyo
    lodaddyo
    Unfortunately ive only got one!
  8. verde742
    verde742
    My opinion: If you only have one, MAKE a hose rack,
    lodaddyo likes this.
  9. Here are a couple of restored Model A wheels turned into 16 inch probably during WW II.
  10. Binger
    Binger
    from wyoming
    I found a set of A wheels made up like that in a stack of 16 inch wires I saw in a barn. I had never seen anything like it. The ones I saw looked scary and not road worthy. It's amazing what some people come up with.
  11. 333tinman
    333tinman
    from MASS.
    It look like a Kelsey Hayes bent spoke that some one cut the center out of . they where welded I have 6 0r 7 that look the same except for the center hole . they also made 40 and 36 spoke wheels . if it has a raised block where the valve stem is it should be 4.5 wide if not it should be 4 in.
  12. lodaddyo
    lodaddyo
    On a Kelsey hayes bent spoke, all the spokes are bent. On this wheel only the short spokes are bent
  13. Rem
    Rem
    Hey, lodaddyo, I've got one the same and just asked the same question as you . . . with the same results! http://www.jalopyjournal.com/forum/threads/identify-this-wire-wheel.1009450/#post-11395615
    Mine was in a 'set' of Ford wires that included a 17" one, a half-decent '35 Ford one and one that I concluded was probably a cut-down 17" or 18" wheel, in a similar vein to Charlie Stephens' and Binger's finds. And that one is probably not road-worthy either.
  14. lodaddyo
    lodaddyo
    Just read your post about the wheel, thats aweosme, what do you think they came off of? Aftermarket wheel maybe?
  15. Rem
    Rem
    Still none the wiser about these. Had a suggestion of Budd in my thread, but they didn't look quite the same. Shame there's a few thousand miles of water in the way or we could get them together and make the start of a set!
    UPDATE: After thinking about what Wheelkid said in his reply I realised I have some Model A wheels here to compare 'ours' with. I thought he was referring to the ones Charlie Stephens posted, but when looking at the back of the Model A wheel you can see the pentagonal shape. Seems an awful lot of work to get a 16" wheel, but the fact that two have turned up a few thousand miles apart and look almost identical suggests that somewhere there was a factory turning these out?
