Technical *** January 2016 Banger Meet - New Year and Old Bangers ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Jan 1, 2016.
  1. Jiminy
    Jiminy
    Here is the banger link list:
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Dannerr, stillrunners and ROCKER77 like this.
  3. winduptoy
    winduptoy
    Sweet start to the New Year
    Have a Happy one
    Larry
  4. V4F
    V4F
    from middle ca.
    looks like a lot of work on the drive shaft . are you making slash aprons also ? ............. steve
  5. 29 Speedster
    29 Speedster
    from Colorado
    Checking In; Happy New Year to all.
  6. I used the '34 shaft and cheated and used a '39 TT as it is only tapered at the front. No splash aprons. It will be an early style "sprint/fairgrounds racer."
    Edit* I guess I am making splash aprons/ hood shelves if that is to what you were referring???
  7. V4F
    V4F
    from middle ca.
    yep . looks like a fun project
    Outback likes this.
  8. denis4x4
    denis4x4
    from Colorado
    No more shoveling snow as we're heading for SoCal Sunday.
  9. 2016?!? already??
    Happy New Year to ALL
    Lets hope that Bonneville can be attended this year.
    John
    rtsidejohnny and ROCKER77 like this.
  10. Dustyp489
    Dustyp489
    Happy New Year ,Hope 2016 shines on us all
    Skip
    ROCKER77 likes this.
  11. blgitn
    blgitn
    Happy new year guys!
  12. höllenteufel
    höllenteufel
    Happy new year to all you bangers!
  13. waxhead
    waxhead
    from West Oz
    Just checking in. Happy new year to you all.
  14. The Brown Sound
    The Brown Sound
    from Maryland
    Happy New Year and all that.
    Anyone ever run a V8 trans without shortening the driveshaft? Curious if that's even possible.
  15. Binger
    Binger
    from wyoming
    Happy New year to the banger crowd!
  16. studebakerjoe
    studebakerjoe
    Happy new year all. Beautiful chassis Cactus1
  17. Totally possible. I have one in my pickup using a clings adapter
    The Brown Sound likes this.
  18. 97
    97
    in what car, behind what motor?
  19. trailerpark
    trailerpark
    Hey all, I have a 31 RPU banger I'm hopping up a little bit. I bought a new Winfield head that is a little rough, what are your thoughts on porting and polishing a banger head?
  20. Juggler
    Juggler
    I polished the chambers with a little flapper wheel on a Dremel. Didn't last long but got the job done and better than as cast
    Dannerr and stillrunners like this.
  21. V4F
    V4F
    from middle ca.
    nice job on your head . to much polish will hurt atomization , (mixing fuel/air) . usually done on exhaust more than intake
  22. Bluto
    Bluto
    New year is a cold start here -11 at noon yesterday
    Our 31 wagon is tucked away in warm storage
  23. noboD
    noboD
    Is the head nurse keeping you in line?
  24. Bluto
    Bluto
  25. The Brown Sound
    The Brown Sound
    from Maryland
    I was thinking of an otherwise stock A drivetrain.
  26. patina steve
    patina steve
    A few engines sitting around the shop...........I think I have Banger Brain
    Dannerr and The Brown Sound like this.
  27. Thanks Joe!
  28. patina steve
    patina steve
    Me too....................1
  29. I posted this question on the Ford Barn but would like to hear what you guys might have to say...
    I'm installing a cast iron Cragar head on a B block and I'm using bolts rather than studs due to firewall clearance. If I install the bolts beginning from the rear and working forward with just enough threads to get them started, the left front hole in the block will not line up enough to get the bolt started. If I work from front to rear, the left and center rear bolts will not line up. The block does not appear to have been machined in any way that would move the location of any of the bolt holes. I've tried grinding a taper on the bolt to get it to start but it doesn't help. Anybody got any good ideas? I may have to go to studs but would like to hear from someone who might have had this problem before. Studs are undesirable because this engine is installed in a model T and the engine setback into the firewall keeps me from lifting the head over the studs. If I should ever need to change a head gasket I would have to pull the motor to get the head off.
