Vintage Sun Tune Up, Testers, Scopes, Analyzer, Distributor Thread
Discussion in 'The Hokey Ass Message Board' started by Flathead Johnny, Oct 14, 2013.
  1. Terranova
    Terranova
  2. oj
    oj
    Dunno about the batteries.
    But anybody ever put a magneto on thier 504? I want to but don't know if the drive is substantial enougth to spin the mag andif the output magneto voltage will hurt the machine? I connect to a sparkplug rack I added so you can see a distributor work.
    Dog_Patch likes this.
  3. oldgoaly
    oldgoaly
  4. Terranova
    Terranova
    One of the battery recepticals is "D" sized but the other one is only half to a third the length of a D cell.
  5. Oldtimermichel
    Oldtimermichel
    from Germany
  6. Truck64
    Truck64
    from Ioway
    To add to that, they (sometimes) used odd sized odd voltage mercury batteries internally in their gear. These would be considered Hazmat. Not sure if that's the case here, but you've got to find a manual reprint somewhere, and a schematic, if you want to get into it much for repair and maintenance.
    Oddball voltages are no problem, even though original type batteries may no longer be available virtually any value can be made up using individual AAAA cells or CR2032, etc, in parallel/series combinations.
    Kan Kustom and loudbang like this.
  7. I found this DT-404 when I went to look at a shop press. The guy wanted stuff gone and I always wanted one of these. I plan to test my magneto on it soon. My buddy 3dnsouth has a machine that spins my magneto just fine, so it should be ok.
    Surprised to see a vacuum tube in here. ;) Right now I just want to spin a mag and check for rev limits so the electronic parts are not priority, but I can update all the caps for good measure.
  8. oj
    oj
    Let us know how it does. I am afraid of that drive mechanism, it takes a lot of power to spin a magneto and I am afraid of shredding it.
    The other thing I am worried about is the current/voltage path - I presume you'll have a sparkplug rack so the magneto will fire the plugs, right? In a magneto it'll fire thru the plug wire to ground on one cycle and then thru ground to the plug wire on the next as it is alternating current. I am afraid of cooking the electronics in the cabinet. Does you buddy have the zenon light operational too? or do you use a timing light?
    Decades ago I had my magnetos converted to external coil and the guy used a Sun machine to test it, I was too dumb to ask what he had done to the machine. I remember he tested it at 8K rpm and it made a hellish racket.
  9. Here is a pic from my build thread - Tim's machine isn't a Sun - I now notice that my Sun makes more noise that this machine. We did run with the spark plugs connected with a wire back to the case.
    Kan Kustom, oldgoaly and loudbang like this.
  10. oj
    oj
    Sweet, maybe I'll hook mine up and give it a try. Thanks. One thing I did, maybe there is a picture of it in this thread, I added a sprakplug rack to mine Sun. When I test a distr it thinks it is on the vehicle.
  11. Yeah I saw where you did that - good idea. I need to build one for mine.
  12. haroldd1963
    haroldd1963
    from Peru, IL
  13. Truck64
    Truck64
    from Ioway
    There's a fellow on that auction site with a Sun distributor machine not too far from me. He's pretty proud of it though, wants 1.9k for it, no idea if it's complete or operational. I think unless specifically restored it would need a fair amount of work to be usable.
  14. Brand Apart
    Brand Apart
    from Roswell GA
    I'm on the lookout for 1 of them myself.
  15. Truck64
    Truck64
    from Ioway
    Well they couldn't give them away for a while. Certainly there is some value, not much demand. Very low WAF I'd imagine.
  16. mr.chevrolet
    mr.chevrolet
    I just got this, came with a bunch of other smaller test equipment. probably gonna sell it. sun2.JPG
      183.7 KB
      171.8 KB
      142.6 KB
  17. Truck64
    Truck64
    from Ioway
    Anybody have a copy of the manual for this version of the Sun Model CB? Or a pointer link to a .pdf maybe?
    It's pretty basic and all but am a little unclear on the carbon pile part of it, and enjoy reading vintage manuals. No BS. ImageUploadedByH.A.M.B.1452642439.380433.jpg
  18. Mounted the magneto and the spark plug rack :) it does seem to work, but there are 2 problems
    - the strobe is only showing 4 locations - plan to change all the old caps in the 404
    - the 3 jaw chuck can't grip the Hemi distributor shaft - need to come up with something here
  19. loudbang
    Check it the old fashioned way. Grab a terminal on the wire and give it a crank... you will know soon enough which ones are not getting spark. :confused:
  20. ago
    ago
    from pgh. pa.
    My Allen Dist. machine is sitting on the same lower cabinet.
  21. Silverplate
    Silverplate
    I picked up this Sun Tester today at an estate sale for three bills. Plugged it in and the gauges light, needles moved and screen analyzer lite up. Has timing light, exhaust analyzer, manuals and lots of cables.
    Kan Kustom, cactus1, loudbang and 2 others like this.
  22. Oldtimermichel
    Oldtimermichel
    from Germany
    Hello,
    Can anyone help me? I need the dimensions of the DT504, for the shipping (from USA to Germany) without Cabinet and possibly approximate weight?
    I have one more question, can do the holder for the distributor, diminish, dismantle, (without big problems?) Characterized the package is substantially smaller. Sun DT 504.png
    I would be very happy about an answer.....
    Greetings from Germany
    Mike-Michael
  23. Oldtimermichel
    Oldtimermichel
    from Germany
    Hello and sorry for my english,
    700 views and no one has an answer for me ?
    Michel / Mike
  24. The notifications for this thread didn't work. Here you go 17 inches deep 21 inches tall 21 inches wide. The posts can be removed with an Allen wrench. That height # assumes you remove the bars. If you unbolt the banner at the top, you can get it down to about 17 tall. Hope this helps!
    Oldtimermichel likes this.
  25. Hey guys, anybody in the Buffalo, NY area interested in an old Allen distributor machine, drop me a line. I want to get rid of this one and it is yours for free, just need a slave to help you get it out of my basement. No shipping, come and get it! Contact Mike at [email protected].
    Dog_Patch, loudbang and slack like this.
  26. Oldtimermichel
    Oldtimermichel
    from Germany
    Hi Dog_Patch,
    Many thanks for your help....what do you think how much the tester without Cabinet weighs?so about?
    Thanks and Greetings from Germany
    Mike/ Michel
  27. Hi Mike,
    I only have a 404 tester and it seems like about 45lbs.
    Tony
  28. jimr23
    jimr23
    Hello . I have a Sun 1020 and 100_3472.jpg I am looking for a Volt/Ohm Meter and A Dwell Meter for it.
    Option #2 would be someone that can repair my meters. they are sticking and not at all accurate.
  29. aba1700
    aba1700
    Hello,
    I'm new. And from the other side of the ocean (the Netherlands).
    A small question. How about spareparts of a Sun 1215? In fact I need a certain board from the oscilloscope.
    Is it possibel to find something like taht here or can somebody help me?
    Thank you in advance.
  30. Happened across this today and have a question or 2. I picked up a Sun 1115 a couple of years ago, and finally got a manual the other day. I will post a picture when I am home.
    But I was talking to a couple of guys here at work, and trying to remember the Sun machine I had on trial in the late 70s or early 80s. I had a Sun 1015 at the time and the Sun guy brought in a new "double trick" computerized Sun machine. It seems like it was a 2001 (like space oddisy), but I cannot find any pictures of one called that. Anyone know what it might have been? btw, I connected it up like my old machine and toasted one of the boards.
    Thanks
    Doug
