Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. Well I decided to use some 8ba heads I have done with bigger chambers........lower my cr give that a shot:D:D:D:D
  2. 64 DODGE 440
    64 DODGE 440
    from so cal
    Iron heads may be more rigid too. I wonder if some of your problems may be caused by unequal expansion rates of the aluminum heads on the filled iron block?
    mctim64 likes this.
  3. Na Tom its caused by too fkn much pressure
    Archiewest likes this.
  4. 64 DODGE 440
    64 DODGE 440
    from so cal
    What the hell are you going to do when you start tipping the nitro can? o_O
    mctim64 likes this.
  5. Hey Tom right now I'm soo close to my goal I don't think there is any nitro in my future.....remember I can't go any faster then 10.0.........
  6. old sparks
    old sparks
    So, are you headed to sac test and tune soon?
  7. soon as I get her back together............
  8. wrenchbender
    wrenchbender
    Hey Carl you might want to richen the carb up she sounds lean even with the first pulley I always thought it was a bit lean now with the smaller one you better fatten the ol pig up or bad things will happen lol good luck at test and tune
  9. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sure you can...Just don't get caught. :rolleyes:
  10. Hey Tom all I'm looking to do is get consistent and not hurt any parts and be close to the mid tens, shouldn't be too hard huh???? unless you and anyone else wants to donate to the cause:D:D:D:D
  11. 64 DODGE 440
    64 DODGE 440
    from so cal
    Sounds like a piece of cake. What exactly is taking you so long! o_O
  12. Hey Carl - do take a look at the Cometic MLS head gaskets - I do think they'd be a LOT better than the copper sandwich ones you're currently running.
  13. Yea Dale I have already called them.................
  14. dragsled
    dragsled
    from Panama IA
    Good luck on your next outing Carl
  15. Thanx Tim. Had a bad day pouring yesterday........... mold collapsed UGGGGGGGGGGGGGG However I did get the larger heads filled with aluminum so I guess it wasn't so bad after all
  16. dragsled
    dragsled
    from Panama IA
    Bummer about the rear cover:(, But getting the heads filled was a plus,:D:D
  17. Yea Tim, I will retry this week sometime I hope........
  18. dragsled
    dragsled
    from Panama IA
    No rush Carl, It's that time of year out here , Beth an the dogs like it tho:D:D:D, Tim Jones GEDC3710.JPG GEDC3713.JPG
  19. 64 DODGE 440
    64 DODGE 440
    from so cal
  20. 64 DODGE 440
    64 DODGE 440
    from so cal
  21. Make note to self....... keep fingers out of spinning bit..........UGGGG
    no wonder its called Bumps n Bruises
  22. 64 DODGE 440
    64 DODGE 440
    from so cal
    When you get done working on it do you count your fingers? Dammit Carl, be careful when working around machinery. :confused:
  23. loudbang
    Ouch and I know it's dear to your heart but a wedding, or any other ring, has no place around spinning machinery either :(.
    1947knuck likes this.
  24. CGkidd
    CGkidd
  25. dragsled
    dragsled
    from Panama IA
    Careful Carl, we work the same way, A piece of alum and a drill press got me the other day, Note to self , use a clamp dummy
  26. Yea guys its the shits getting older but not wiser...........
