Technical chevrolet spindle dimensions
Discussion in 'The Hokey Ass Message Board' started by srcracing, Nov 24, 2015.
  1. srcracing
    srcracing
    I need the dimensions of a 1949-1954 chevrolet car spindle. Going to cut disc brake caliper brackets. Anyone have these measurements?
  2. squirrel
    you probably ought to get one in your hand before you get too far along...
    volvobrynk likes this.
  3. 33sporttruck
    33sporttruck
  4. gimpyshotrods
    gimpyshotrods
  5. flatheadgary
    flatheadgary
    from boron,ca
    i have found that this type of kit will not work on a straight axle but does work on a dropped axle.
    i tried to fit this on my straight axle and i found that the caliper puck area would hit the axle and shorten the turning radius. i believe since the caliper is bolted at the 3:00 o'clock position it wouldn't work. i tried it on a 4" dropped axle and the caliper puck would go into the drop area alright for maximum radius. i think for a straight axle the caliper needs to at the 12:00 o'clock position. anybody else have this problem?
  6. gimpyshotrods
    gimpyshotrods
    The OP has a passenger car IFS.
    I believe that if you tweak the steering arms, this kit will work.
  7. OLDSMAN
    OLDSMAN
    Like has been posted Speedway has a great picture and dimensions for the Chevrolet spindles
