Mint Corvair pitman arm. Bent to clear early Ford frames. Taper reamed 7 degrees to mount Ford tie rod end from the outside. Splines professionally modified so the pitman arm indexes "straight down" for Model A's, etc. You can also mount this arm "straight up", for bucket T's. You can, however, mount the arm in any position you want. Shipping is $14.00. You can, however, mount this to the box in any position you want.
