Hot Rods Firestone 890-16 dirt track wheel size?
Discussion in 'The Hokey Ass Message Board' started by slick36, Oct 15, 2015.
  1. slick36
    slick36
    Curious what Rim width people are running with these? i know they recommend a 6"-8" but has anyone mounted them to an original 40 ford wheel (16x4.5)? if so do you have any pictures. I am trying to decide between a 16x4.4 or a 16x6 wheel. I know the 16x6 wold probably be the safer route but i like the skinnier look that i see in some pictures. Picture of both would be VERY helpful.
    I really like this setup but cant find what he is running. [​IMG]
    i dont like this look as much
  2. 3wLarry
    3wLarry
    from Owasso, Ok
    the above pic is a 4.5"-5" wide wheel...they work just fine
    kidcampbell71 likes this.
  3. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I mounted mine on 7's so the contact surface stayed flatter.
    X38 likes this.
  4. TLB@HCG
    TLB@HCG
    This 890-16 is mounted on a 16x5 Rocket Solid wheel. It should be fine on a 16x4.5, but it might create a "crowned" tread. The crown and the bulged sidewall looks cool (in my opinion) but it may cause some instability. It's a tall sidewall, and not much contact patch (when the tread is crowned like that) so it might feel a little squirrely on the highway. Firestone-Dirt-Track-890-16 copy.jpg
  5. Blue One
    Blue One
    from Alberta
    A 6" wheel will allow the sidewall to work properly and keep the tread flatter for good tire wear and traction.
  6. slick36
    slick36
    thanks for the responses
