Reduced price: $75,000. USD Regrettably: Due to the declining health of the owner, this 1932 Ford 5 window coupe is being offered for sale after 48 years. Car is late model 18, and is uncut ALL STEEL. Owner has retained, through the years, the original and unequaled beauty of the 32 Ford. Original odometer reading indicates less than 45K miles. Car sheet metal is virtually rust free with one postage stamp size repair on lower cowl. All original wood with the exception of the three middle top bows which were replaced because they had become flat. Car has recent black base coat clear coat paint by Harold Clay, Enid, Ok. Body and door gaps are very good and straight. Has original door latches, window regulators, top trim tack strip, working cowl vent, original locking column drop/ignition switch, chromed windshield frame, original radiator collar with original script, original seat and uncut dash. ' Modifications include: boxed original ''to this car frame'' rails, P & J frame cross members, 69 4 bolt 350 small block Chevrolet, turbo 400, 9" Ford rear with 325 gear and limited slip, SoCal forged dropped I beam axle, Vega steering, Limeworks 40 style steering wheel and column, four bar front and rear, coil over rear, disc front, 11" Currie drum rear, Deuce Factory anti-roll, Walker Z series radiator with condenser and Cooling Components electric fan, Vintage Air compact Gen II AC, Classic gauges, Gennie shifter and parking brake handle. Rear fenders (Brookville), running boards (V8 Shop), and bumpers are reproductions. Wheels are steel, 15" front, 16" rear with early Ford caps, and Michelin tires. List of components are available as well as pictures during construction. Note: Successful buyer will have the option for some additional original parts including instruments panel referenced above. Serious inquiries only, contact: Jack Mannen 405-812-4932
