Use the Chassis Engineering set up worked on My '41 Pickup & 1940 ford coupe designed to work with the CE Frong sway bar set up also. If you plan on updates on the front end other than the shocks stick with one vendor that way all the parts will work and you should not experience hic cups in the installation geoford41
