Technical 46 ford pick up removing rear brake drums
Discussion in 'The Hokey Ass Message Board' started by chewie1, Aug 22, 2015.
  1. chewie1
    chewie1
    Hi
    I have a friend 46 ford pick up in the work shop we are a bit stuck at getting the rear drums off
    Is there a secret we are missing as they seem to be stuck fast. 20140806_161526.jpg
  2. Budget36
    Budget36
    You'll need a hub puller, the hubs fit over a tapered axle, think of it like a steering wheel taper.
    There is a specific Ford tool for the job that fits over the collar on the drum, but I always had good luck with the 3 "legged" pullers using 3 of the wheel studs.
  3. chewie1
    chewie1
    my mate broke a 3 legged puller all ready. (it was a cheapish one mind) lol
    and i bolt a chain to three bolts and tried a 10Ib slide hammer on it
    is there a woodruff key in there that needs to come out first
  4. Budget36
    Budget36
    There is a key, but it will come out with the hub, don't think you can get at it anyways.
    Actually, my memory just clicked, it's a KR Wilson hub puller, not Ford.
  5. Yes you need the proper hub puller,and maybe some Heat.
    Check Vintage Precision.com---800-486-0021.And thanx wbrw32.:D
  6. PLUS a BIG F'n hammer
  7. I am not that familiar with trucks but I would assume this puller is the same one used for cars. If that is correct the same puller was used 1928-48 so also check with some of the Model A guys when looking to find a puller. To bad you are not on this side of the pond, Mac Vanpelt ( http://www.vanpeltsales.com/FH_web/flathead_home.htm) rents the correct puller. If they are not stuck they probably were not installed tight enough.
    Charlie Stephens
  8. chewie1
    chewie1
    Ok guys thanks
    some heat will be the next approach
    and a bigger hammer :)
  9. How about getting on the phone and looking for someone with a good puller, as I said in my post I think the same puller was used 1928-48. A good puller is usually less expensive than a new axle.
    Charlie Stephens
  10. oldrelics
    oldrelics
    from Calgary
  11. chewie1
    chewie1
  12. chewie1
    chewie1
    should be able to find one of them over here. otherwise it'll be a home build tool like oldrelics
