Projects 37 ford half ton pickup build
Discussion in 'The Hokey Ass Message Board' started by flathead 37, Jan 5, 2013.
  1. ntxcustoms
    ntxcustoms
    from dfw
    The stock mount worked only because it rode on the closed torque tube which rotated as the axle moved.
  2. flathead 37
    flathead 37
    i thought that the old wishbones may be a problem. any suggestions on how you guys would do it. any pictures or examples?
  3. Bob metke
    Bob metke
    I also am redoing a 37.53 Merc,39 tranny and juice brakes done in the 60's.I want this truck to be the way we did them in the 60's.Still trying to get out the spring perch bolts out.Any suggestions?Flatheads forever
  4. Deucefanny
    Deucefanny
    from Australia
    A little heat and a good whack with a big hammer 'should' get them out. If not you might have to oxy cut them out.
    Good luck.
