This differential is in my 59 Chevy Apache. I'm pretty sure it's not the original. It was in the truck when I bought it. I know it's a GM rear but that's all I know. It has drum brakes and I want to do a disc conversion. How can I identify the donor vehicle it came out of ?
Looks like a factory four-link. What's the bolt pattern? If it's a car bolt pattern, possibly G-body. If it's truck bolt pattern, possibly full size GM like Buick or Caddy. Rich
It won't be a truck because they had different mounting. Will be a GM car axle that came with rear coil springs.
There are a couple of different GM 10 bolt rearends it could be, or it could be a 12 bolt. Can you get a picture of the rear cover?
soooooo... 1. Determine lug pattern. 2. Get good pic of back cover. 3. Measure width, backing plate to backing plate. Rich
If you're looking to do a disk brake conversion, I'd ask "why"? Not much braking action going on with the rear brakes in an old pickup truck, since there's hardly any weight on the rear wheels when you're stopping hard. btw the size of the rear brakes it has now will help figure out what the rear is out of. Mostly the full size cars used 11" brakes, midsize cars used 9.5" brakes.
A very belated thanks to all who responded. Squirrel's point resonates with me. The truck stops just fine with rear drums and front disks
