Technical front section of the rear quarter panel on 1954 Chevy 210
Discussion in 'The Hokey Ass Message Board' started by 54rat210, May 18, 2015.
  1. 54rat210
    54rat210
    Been a while since a posted last. I have a question. How do I made up the front section of the rear quarter panel on my 54? Where does the bottom connect or have to be welded to?
  2. 54rat210
    54rat210
  3. low budget
    low budget
    from Central Ky
    I would say the same place the old one is mounted to unless you dont have that either.
    inner rocker,door jamb post (or a inch or so back from it)and lap or butt weld to good rear section of quarter???
    Im not a pro but I could probably make a pretty good guess by looking.
  4. 54rat210
    54rat210
    I don't have that either. I'll post a photo
  5. 54rat210
    54rat210
  6. 54rat210
    54rat210
  7. 54rat210
    54rat210
  8. 54rat210
    54rat210
  9. I hope you are better at metal work than you are at photography
  10. 49ratfink
    49ratfink
    we can't tell what you are trying to do with those photos
  11. 54rat210
    54rat210
    @wbwr32
    How do I mate up the front section of the rear quarter panel on my 54? Where does the bottom connect or have to be welded to?
    The photos are explaining the situation I'm encountering.
    The photos are pretty clear of what I'm encountering.
  12. 54rat210
    54rat210
    What more photos do you need?
  13. 49ratfink
    49ratfink
    I've had 4 1949 Chevys, a 51 and a 53 and I have no idea what part of the car we are looking at.
  14. 54rat210
    54rat210
    @ratfink. I'm trying to mate up the front section of the rear quarter panel on my 54 Chevy. I have no where to weld to on the underside. Am I missing something? I have a gap between the outer panel and the rocker. Should it mate up to the rocker?
  15. 54rat210
    54rat210
  16. 54rat210
    54rat210
    There is a gap between the rocker and the patch panel. They don't connect it meet.
  17. 54rat210
    54rat210
  18. 49ratfink
    49ratfink
    looks like you replaced the inner rockers as well as the quarter. either the rocker does not go far enough down or the quarter was put on too high. the inner rocker is supposed to butt weld to the lower flanges on the quarter.
    edit: I see the new picture, the rockers need to go down further to match where the quarter is
  19. 54rat210
    54rat210
  20. 54rat210
    54rat210
    @ratfink. Let me know exactly what photos you need. I'll do my best to take them for you.
  21. 54rat210
    54rat210
    That's interesting. Seems that the rockers are too short? Damn. What now?
  22. low budget
    low budget
    from Central Ky
    Looks like a pretty good size gap between the fabbed floor and the floor brace that could be causing the inner rocker to sit too high, also looks like the fabbed panel at the bottom is either too short or the quarter patch section is sitting too low, however the quarter section looks o.k. in the outer picture of it.
    **on second glance of my pic, it looks like the lower circled part is just forward not up**
    Just looks like to me its gonna take some adjusting and trial and error 20150518_170153_zpstykme6ya.jpg
  23. 54rat210
    54rat210
    Yeah. The car was really rusted. I started fitting pieces together. The rockers outer and inner eliminated the gap up by the door. Yeah I had to make a floor board and that kennel. The panel was hanging low. When it's snugged up it lines up with the patch panel I made. I may have to trim it down slightly.
    Thanks for the reply
  24. 54rat210
    54rat210
  25. low budget
    low budget
    from Central Ky
    Depending on what level of perfection you are going for, undercoating will help hide a lot of imperfections on the underside if you can just get er welded up where its solid
  26. henry29
    henry29
    Is the other side the same? Did you make the inner rocker or buy it?
  27. 54rat210
    54rat210
    I purchased it. @henry29. The other side has to be worked on as of yet. That side is worse off. But the rocker is installed.
  28. 54rat210
    54rat210
    @lowbudget Yeah I figured I would cover up some of the blemishes on the underside with undercoating.
  29. ems customer service
    i sent you a pm, your off in the wrong direction before you make a mess i will call and help you out,
    the ems guy ems automotive
  30. 54rat210
    54rat210
    Pm reply sent
