Hot Rods Good bye Flaty, HELLO Caddy!
Discussion in 'The Hokey Ass Message Board' started by CheatersPete, Mar 30, 2015.
  1. 40fordtudor
    40fordtudor
    Wow---Atwater Mike just reminded me of Dick Sansoni's 40 Ford Tudor, circa 1959-61. He didn't get on it much, but when he did it had balls. Damn. 5/1--edit: it was a 331 with a 39 toploader.
    lothiandon1940 likes this.
  2. CheatersPete
    CheatersPete
    Thanks for the story Mike, Unfortunately, it is a complete different story now to find the parts needed to install the caddy in a 32...;-)
  3. rod1
    rod1
    Loving the updates,Pete.I really enjoyed your build in the beginning,now it's that much sweeter.
  4. Bert Kollar
    Bert Kollar
    Brings back memories of "back in the day " in about 1954 or 54 a club member had a homemade sports car with a forty Ford frame, '39 tranny and a 331 Cadillac with a two barrel carb. First time out at the Akron drags he beat a Mercedes 300SL. Came back to the pits with his helmet on backwards he was so happy.
    Atwater Mike likes this.
  5. CheatersPete
    CheatersPete
    Here is a few pictures of the engine now sitting by his own in the car
    Unfortunately, The exhaust manifold I ordered are for 331, I didn't know that 365 have larger exhaust port, therefore, I have to find a set of 1959/60 exhaust manifold with center outlet in order to finish the installation...
    Does anyone know if shorter water pump exists? I have issues with the Fan blade hitting my radiator...
    thanks
  6. coupe33
    coupe33
    As far as I know all the water pumps are the same length.
  7. Hdonlybob
    Hdonlybob
    Nice switch, and totally goes with your car...
    Also I would assume you will enjoy cruising at higher speeds when necessary a lot more with the Caddy :)
  8. CheatersPete
    CheatersPete
    Here is last night pictures, waiting for my exhaust manifold to start the beast...;-)
    Jet96, tevintage and wvenfield like this.
  9. CheatersPete
    CheatersPete
    Exterior pics... rain finally stop...;-)
    Martin_F likes this.
  10. Pete
    Pete
    Find a different water pump pulley, one that's not as deep, press the hub that the pulley bolts to farther on the shaft, trim the excess shaft. I've done this a few times and it works fantastic
  11. CheatersPete
    CheatersPete
    Thanks , I found a fan that fit ;-)
  12. bobo1
    bobo1
    from France
    Wouaaaaa Super Pete :)
  13. chrisp
    chrisp
    A couple years ago I had perfect exhaust manifold for sale dirt cheap (30 Euro) from my 390, nobody got interested. I gave them to my scrap guy neighbor, he was very happy. Had I known I would have kept them for you.
  14. harleycontracter
    harleycontracter
    I was told by a friend and a guy who knows WHAT to use to build it right when building a hot rod without a flatty the ultimate motors to ue were Caddy and Olds. Should be ready to finally fire mine this week or next.
  15. CheatersPete
    CheatersPete
  16. CheatersPete
    CheatersPete
    Chris, I'm working on this engine from the last month only...thanks anyway ;-)
  17. what kind of carb linkage are you going to use.
  18. CheatersPete
    CheatersPete
    direct linkage, with cable throttle pedal
  19. sorry, progressive or 1 to 1. motor looks awesome. folks really dig something different than the flathead. I get lots of questions on why I have an olds mill in my 53 chevy. Because THEY did....
  20. CheatersPete
    CheatersPete
    1 to 1 linkage , I did a few hot rods with flathead, from mild to wild, strokers, blown... and still love it, I just had the possibility to get this caddy mil, and decide to follow the ''what hotrodders did in the mild fifties'' and of course , the idea of running more power is always a motivation
  21. CheatersPete
    CheatersPete
    Hi all, here is the start of the engine, running good, I will have to redo the engine as i have a lot of blow by...
    ace5043, gas & guns and Jet96 like this.
  22. ROBERT JAM
    ROBERT JAM
    Just a great looking car!!
  23. Sounds great and I like those exhaust manifolds
  24. Blowby is traditional... it may clear up a bit as you run it.
  25. CheatersPete
    CheatersPete
    I have a lot of blow by....but installed a PCV and it do the trick for now ;-)
  26. cody1958
    cody1958
    from wichita ks
    great choice. Im a big fan of the looks of the caddy motors with all cool speed parts one them. Stock is cool to. Nice car!!
  27. mgtstumpy
    mgtstumpy
    Always loved the old Caddy mill and can't wait to see it fire up and move again under its own power.
  28. gas & guns
    gas & guns
    I can smell the rubber now. Great job.
  29. CheatersPete
    CheatersPete
    little video, lot of speed bumps , will try to make a better one soon...
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    sounds great man! way to go!!
