I wanted to go oldschool on this one,so i decided 2 go with the 324 rocket,if any one has any tips or advice on installilation let me know.......
As I recall, if you use a stock Olds pan you need a "dropped" tie rod center link for pan clearance. There may be other relatively minor clearance issues, but I think that is the main one. Ray
what about mounting the engine - it is a front mount engine, the flatheads weren't. Is there an article out there or suggestions by others who may have done it?
You use a hurst style mount on this install and aside from pan clearance there is also a starter clearance issue as I recall. That said they along with the caddy were a popular swap into the old fords way back when. The starter issue is overcome with a starter swap from driver side to pass side. GOATROPER02 here on the board will have everything you need to make this happen and he'll treat you right while he is doing it for you.
