Help: Have a real NOS Ford flathead radiator with filler NOT in the center. Large tank at the top. What were the years of Non centered filler cap in the thirties? Or maybe this is for a truck?
Typical Newbie Sorry. Will post up a couple tomorrow, this thing is neat, still in the original carton. Pics tomorrow.
Does it have a large nuber pressed into upper tank...like 81, 91, 01? If so that is the PN prefix and will allow quick ID.
35 up for the radiator cap inside the grille shell. Do a Google image search just change the year. Should be pretty easy to find.
This stolen picture shows what you are looking for...the numbers pressed into top tank will immediately ID Ford radiators after about 1936. Essentially most of those used after visible caps disappeared....
68 would be '36 passenger designation, L probably one of the several radiator suppliers. Hig Google advanced image and see if it matches that... I think this one is a '36...image searching can be flakey.
Yep. This is it exact. Folks now saying 35-38 all same, but at least I know this is a 36 thanks to you. Thanks for your time.
