For sale asap 12k 1929 Ford Sedan Body : Chopped 6”, 4” Channeled , Rear window sectioned, Drip rails shaved ,..Visor modified. Original frame Boxed and 4” Z kickup in the rear. 1951 Ford Shoebox speedo /gauge cluster Vintage (and working) Dixco 8000rpm Tachometer Has modern oil pressure and temp gauges. EZ wiring harness Engine: 1969 302 Block, 4bbl Heads Milled to 50cc, ported and gasket matched. 1.94/1.60 stainless valves Roller rockers with retainers 1.6 to 1 TRW forged .068 dished pistons 292/534 cam Zero Decked Balanced High volume Melling oil pump 8qt moroso oil pan ARP fasteners Victor JR intake 600cfm 4bbl edelbrock carb Vintage Cal Custom finned valve covers MSD 6AL ignition box and distributor Lake headers with custom removable baffles. mustang radiator Trans: Ford FMX 3speed automatic 12” aluminum Trans Cooler 8 gallon sheet metal fuel tank , Brass flip gas cap Ford 8” rear end 3.00 to 1 posi 1939 Ford Banjo steering wheel Limeworks stainless steering column Vega steering box Gennie shifter hand carved skull shift knob made from spalted maple 1929 Texas plates not included!
