Been awhile since I've been on the board, but I seem to remember a post about alternatives to dyna may or hush mat. It was stated that Home Depot or Lowes sell a material that is used to wrap hot water heaters or boilers that is identical and much cheaper than dyna mat or hush mat. Has anyone ever used it and what are your thoughts about it?
Works great seems like it is found in the roofing supplies. I put it all over my 38 Project it's silver backed and sticky tar like on the front. Cuts with a pair scissors.
Thanks for the reply. Were you satisfied with the results? While I used lizard skin on the bottom of my cab floor, I'm looking to cut down the amount of heat radiated from the exhaust through my cab floor and firewall. All unnecessary holes have been filled
Peel n Seal is the rubberized/tar type roll and stick on stuff, works very well. I also put Reflectix in my cab, similar to what HRP posted. Makes a great heat barrier. Both sold at the lumber store.
