Hot Rods How many revs on a flathead
Discussion in 'The Hokey Ass Message Board' started by Mean Lean, Mar 26, 2015.
  1. Mean Lean
    Mean Lean
    I start doing testruns on my project Flathead with a Volvo overdrive gearbox with a S10 3. someting rear, so far I got 60 miles/h with only 2000 rev's and it still pulls. I must say a lot of fun, the smile is not of my face for a while...
  2. Mean Lean
    Mean Lean
    ok the question was, what rev's do you normally drive at 60 m/h..
  3. mj40's
    mj40's
    With the right gears and tire size, I would say around 2000 rmp would be nice for a flathead. I had a full race 296 Merc flathead that was balanced in the 70's and it would come alive at 4000 rpm and still pull at 110 mph. Never should have sold that one.
  4. LjH
    LjH
    Turning 3500 @65, 39 toploader pulling 3:78 banjo.
    Love to know more about the volvo box!
    lothiandon1940 likes this.
  5. AVater
    AVater
    1. Connecticut HAMB'ers
    60mph at 2000rpm is a pretty sweet spot to be in. How are you making out starting off on a hill?
  6. ronnieroadster
    ronnieroadster
    60 MPH and 2000 RPM is nice I have found driving highway speeds the flathead likes to be up to about 2200 RPM pulling a good highway gear the engine will pull along nicely at well over 70 MPH. Rear end ratio in my halibrand with a C-4 is 280. Running a five speed with a .78 overdrive rear ratio in my halibrand is a 319 in fifth gear the final drive is 246 ratio. Many miles with smiles for sure.
  7. lowsquire
    lowsquire
    from Austin, TX
    2100 at 60 MPH , .78 overdrive 5th , 3.54 diff ,700x16 tyre.
  8. Pete1
    Pete1
    from Wa.
  9. 3wLarry
    3wLarry
    from Owasso, Ok
    our 296/ 8ba flathead powered hamb dragster ran 6000 rpm thru the traps at 12.78/107mph :)
  10. Mean Lean
    Mean Lean
    Thanks all you guys for the input, last week I put a broadband lambda sonde in the exhaust for measuring the fuel/air ratio and it sits nicely around 14.3 all the way, accelerating and cruising.
    Here is a pic from the Flathead/Volvo combination.
  11. tubman
    tubman
    How heavy a car? The one in your avatar? I have been thinking about this setup for my '51. I believe I would have to go to a little lower (higher numerically) rear. Anyone have any thoughts or experience with this?
  12. Jimmy2car
    Jimmy2car
    from No. Cal
    I have a similar setup to Mean Lean using a GV O/D behind a Ford toploader.
    Using a 4.11 rear axle gear, in O/D becomes 3.21
    About 2400 rpm @ 65 mph w/ 29" tire
    AVater likes this.
  13. Mean Lean
    Mean Lean
    No it is not the car in my avatar, it is a '32 Plymouth tudor, about 1220 kg, you do the measure..
    stealthcruiser likes this.
