Ok 2" blocks are in. The front has settled down into the springs a bit too. Im happy with the drop thus far. Problem now is, im starting to think about power brake conversion. Which leads into disc brake conversion. Which leads to 14" wheels. Then an engine swap.... Does it ever stop?
I did it on a falcon once, seems like I had an article that I procured somewhere and I don't remember all that was involved (measurements) but it improved the falcon a ton. if that is of any value to you. Personally I think you should lift it about 8" in the front and 6" in the rear and make a "gasser" out of it. Like special ed said drop it and drive it nice car.
Has any body try using Aerostar coil springs . Just installed after market front coil & now it looks like a GASSER LOL, I KNOW IT NEEDS TIME TO REST. DOING A 63 COMET I-6 , 3 SPD. FOR THE WIFE. THANKS LOU.M.
