Hot Rods Anybody run their flathead powered hotrod on a Dyno?
Discussion in 'The Hokey Ass Message Board' started by Flathead Coupe, Mar 6, 2015.
  1. Flathead Coupe
    Flathead Coupe
    How many of you ever put their flathead powered hotrod on a dyno?
    What kind of numbers did you pull at rear wheel?
    What engine configuration?
    Im going to put mine on a dyno tomorrow and I am curious on what kind of numbers I should expect at the rear wheel compared to other flathead powered cars.
    Thanks in advance for responses....
    My engine configuration:
    8BA ported and Relieved (276 cu in)
    4" crank
    Potvin 3/8 full race street cam (375 lift & 280 duration)
    Offy 4.00 Heads
    Offy 1075 intake w/ Dual 94s (edelbrock 94s running stock power valves and #44 jets)
    Ill run Sunoco 110 for the dyno pull
  2. banjorear
    banjorear
    Please report back. I'd really like to know how it does. When you say Potvin Full Race, which grind is it? Thanks.
  3. Flathead Coupe
    Flathead Coupe
    Edited post..
    Running a Super 3/8 Potvin
    Full race street cam
    375 lift & 280 Duration
  4. jseery
    jseery
    from Wichita KS
    140 to maybe 160 hp range. There have been a number of books written on dyno runs on flatheads of different configuration. JWLs book is one.
  5. Baumi
    Baumi
    A friend had his AV8 on a dyno, it pulled a little over 160hp and he broke his trannys regularly. 8BA , Merc crank, 2x2, but I have no idea what the internals were.
  6. Any chance you'll be running a video? This'll be cool.
  7. Where is the dyno? Rick
  8. jseery
    jseery
    from Wichita KS
    Flathead Facts, by John W. Lawson.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Ran my T bucket years ago. 276 Merc. Offy 400 heads, mystery cam, Offy 2x2 with 94's, Pertronix, adj. lifters, no relief, 5 spd and a banjo. Really, REALLY short driveshaft and bias plies. Went from 116 to 130 even with just tuning by the best in the biz....Dave Heniger.
  10. Flathead Coupe
    Flathead Coupe
    I won a free dyno session at the Creative Workshop in Ft. Lauderdale
    During their Cars & Coffee tomorrow morning.
    I will definitely record it with my phone and a GoPro, and post results.
    I have read a few books on the subject... But am looking for more real world numbers from cars that have been driven and normal use. I have quite a few miles on my rod and run the snot out of it.
    volvobrynk likes this.
  11. flatheadpete
    flatheadpete
    from Burton, MI
    I beat the lovin hell outta mine....1500lbs and 130hp was fun!
    volvobrynk and Flathead Coupe like this.
  12. Flathead Coupe
    Flathead Coupe
  13. jseery
    jseery
    from Wichita KS
    That looks like a Hot Rod! Kids today!!
    Flathead Coupe likes this.
  14. Eager to see the results.
  15. warbird1 likes this.
  16. Flathead Coupe
    Flathead Coupe
    Topped off with 110, waiting for the Dyno
    guthriesmith and volvobrynk like this.
  17. Flathead Coupe
    Flathead Coupe
  18. Flathead Coupe
    Flathead Coupe
  19. Buddy Palumbo
    Buddy Palumbo
    I love the pic with the B-17 , two great-lookin' rides . Can't wait to see what the flatty pulls on the dyno.
  20. prpmmp
    prpmmp
  21. flatjack
    flatjack
    Never had mine on a dyno. Will really be interested to here your results. Got basically the same engine , but with a Winfield SU1-A cam.
  22. Terry Buffum
    Terry Buffum
    from Oregon
    My similar engine on an engine dyno produced 175 HP, so I agree with jseery that you'll see about 155 at the rear wheel.
  23. flatjack
    flatjack
    I'll be surprised if it is that high.
  24. orangeamcs
    orangeamcs
    Does the dyno yoh are running it on have a eddy brake? It will make more accurate power w one of those. Post up the dyno jet numbers. They are basically inflated numbers but it's the industry standard. Would be curious to see what you air fuels look like and what the fatty like as far as they go. Question is, why run 110? Do you always run 110? I would want to know what it would make on your normal fuel. My suggestion would be to baseline it and set a/f on normal fuel and then start adding 110. It will possibly make less power on 110 if it's not tuned for it. Your combo may not even have enough compression to take advantage of it either. Then again I've never dynoed a fatty or owned a running one yet.
  25. banjorear
    banjorear
    Forgot about this. How'd you do?
  26. 56shoebox
    56shoebox
    Maybe he hasn't gotten off the machine yet. "Jane! Jane! How do you stop this thing?!!!"
  27. NMCarNut
    NMCarNut
    Never had my 36 on the dyno but several engine runs were made before installing. Engine specs are:
    284 cid 8BA ported and relieved
    3-5/16" bore 4-1/8" stroke
    1.6" intake and exhaust valves
    Isky Max 1 cam
    Edelbrock 1116 heads
    I run one of Joe Abbin's not so traditional Holley 570 cfm/Weiand 142 supercharger kits but the engine initial run-in was with an Offenhauser triple intake and Stromberg 97s. Dyno runs were made both with the 97s and the supercharger with a graph below for the best runs in both configurations:
  28. Nothing to do with the original post but thought it was pretty interesting.
