Technical Bringing back old chrome
Discussion in 'The Hokey Ass Message Board' started by Gerg, Mar 4, 2015.
  1. Gerg
    Gerg
    Alright here are some more pics. The proof is in the pictures like I have said before this is not a permanent solution. This is to last long enough to afford new chrome.
    This is the side not done yet.
    This is the side that I have been working on.
  2. Gerg
    Gerg
    This is soaking
    Done and polished.
  3. Gerg
    Gerg
    Last picture of the night just showing some of the work coming up.
  4. JesseOdomTattooer
    JesseOdomTattooer
    from Plano
  5. Gerg
    Gerg
    Quick update to that bumper.
  6. Gerg
    Gerg
    Just some shiny shit.
  7. BLUDICE
    BLUDICE
  8. Fender1325
    Fender1325
    Looks good. All Ive used that works is some steel wool and a bucket of water. Keep it wet and scrub away
  9. dudley32
    dudley32
    tin foil and catsup works very well on older chrome...the acid in the catsup helps dissolve the rust...I don't recommend using it on newer chrome...I did and it marred the finish...
  10. pitman
    pitman
    Was that Ratatouille I saw reflecting in that pic? :)
    Looks great when polished up!
  11. I have also had good luck with the super fine steel wool. I haven't found it to scratch if you use it lightly. It can make horrible chrome look good enough for a driver. You just have to keep at it since once your chrome is that bad then it will always return to that state.
  12. I just use Blue Coral metal polish with a cloth buffing wheel on a drill.
  13. yruhot
    yruhot
    Looks like the top of my head.lol. Are you saying to use my head?yruhot
  14. Gerg
    Gerg
    Here is the finished product
  15. Looks good. It sure is better than those painted over bumpers.
  16. Gerg
    Gerg
    I am happy with the results. And waabz is happy so it was worth the time and experimentation
  17. No fix is permenant, once the chrome starts to go it is not coming back no matte what you do.
    I like the look of old chrome on an old car, if the car is getting a fresh pristine paint job that is a different story but if you can clean up the chrome on an old car and the car is not already rusting away then it does a lot to make it presentable.
