Technical Show What You Made With Your Lathe
Discussion in 'The Hokey Ass Message Board' started by Gauder the goof, Feb 12, 2015.
  1. I'm finally upgrading from my tiny atlas to a large toolroom style lathe. Show me what you've made for your hot-rod, or any other fun parts. I need some ideas.
    Also just picked up a 16" rotary table for my mill.
  2. blowby
    blowby
    from Nicasio Ca
    Congrats, bu keep the Atlas. I still use my bench lathe more than my big Sheldon. Anything smaller than a couple of inches, spacers, bushings, bolts and what not, goes in the small one. Also use the rotary table quite a bit for bolt circles.
  3. ratrod72
    ratrod72
    Yes definitely keep the small Mach..I have a wade 8a lathe 36" bed an a Hendy conehead 72" bed a gorton 9j mill and a kwilway boring bar.. Very useful in building hotrods with modifying suspension brakes an drivetrains... An you can make some very professional looking brackets spacers fittings bolts .. My newest Mach tools are about 65 years old.. I collect them like I do old cars....
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Lots and lots of suspension components - 4-links, panard bars, even narrowed Ford 9-inch rear ends. Plus lots of engine component work - polished crankshafts, cut down valves, pushrods. The list is as endless as your imagination and ingenuity.
  5. squirrel
    I made a pair of huge nuts.
    And a bunch of other stuff, too.
  6. I was born with them,lol.
  7. burl
    burl
    from Minnesota
  8. '51 Norm
    '51 Norm
    from colorado
    I seem to make tools more than parts. No pictures but I made a hammer form to make an air cleaner base. And my wife won't let me forget the time that I cut the bottom off of the Christmas tree to make a clutch pilot tool.........Hey the parts store was closed!
  9. Biggest things I use mine for on hot rods,,,, make spindle bearing adapters, fit kingpin bushings, make suspension components (like fit tubing for bushings), make bungs (for split bones). As you can see, for building hot rods, its a money making/saving tool.
  10. TagMan
    TagMan
    I make a lot of chips on my 13" Southbend. Sometimes I even make stuff I can use !!
    270dodge likes this.
  11. dreracecar
    dreracecar
    from so-cal
    Dont know about the rest of you, but----
    blowby likes this.
  12. DDDenny
    To quote Larry the cable guy "I don't care who you are that's funny right there"
    Jim--I just couldn't resist View attachment 2834793
  13. DDDenny
  14. john worden
    john worden
    from iowa
    Set of headlight rim 000_0825_resized.JPG finials made with a 1917 Lodge & Shipley 8x48 lathe in a 1919 building for a 100 year old car. Work done by Mike W.
  15. rocketsled59
    rocketsled59
    I just made a mess RS59
  16. Marty Strode
    Marty Strode
    Max Gearhead and Tim_with_a_T like this.
  17. 19Fordy
    19Fordy
    Oil fill tube.
    Aluminum fan hub pulley.
  18. Dave Mc
    Dave Mc
    My Dad made 5 of these miniature 21" Model A Wheels as Trophies for the Local Chapter of MAFCA
  19. I was able to make my finger shorter...................
    clem, squirrel and Dave Mc like this.
  20. [Q="CTFuzz, post: 10843720, member: 553"]I was able to make my finger shorter...................[/QUOTE]
    :eek::eek::eek::eek::eek: yikes!!!!!!!!
  21. DDDenny
  22. DDDenny
    Been try'n to upload pix, says error, too big
    Among the many parts iv'e machined for this car are:
    Air cleaner heavy washer and knurled nut
    Thermostat spacer and water neck
    Belt idler, and tension adjusters
    K&N breather adapters
  23. Fabber McGee
    Fabber McGee
    putting a 2 speed Fuller auxiliary transmission in my Grumman step-van. Built u-joint adapter, yokes and driveshaft. Twinkie Hotel 15 036.JPG Twinkie Hotel 15 037.JPG Twinkie Hotel 15 045.JPG Twinkie Hotel 15 103.JPG
    tb33anda3rd likes this.
  24. DDDenny
    Let's try this again
    Belt idler, tension adjusters & spacers,etc.
    Thermostat spacer& water neck
    Air cleaner knurled nut and conical washer
  25. DDDenny
    CRIPES!!!!!!!!!!! I don't get it, Says error again
  26. JC Sparks
    JC Sparks
    from Ohio
    Management system and pressure plate for a multi stage lockup clutch for a top fuel harley we ran a few years back. JC
  27. '52 F-3
    '52 F-3
    fuel block..... for my 6x1 carb setup.
    Tim_with_a_T and Zaq like this.
  28. I cheated a bit, took a trade school course so I could get on a CNC lathe.
    these!
    made this!
    that made this!
    which was needed to make this!
    A one off sleeper for my truck project!
  29. DDDenny
    Raise your Halon fire bottle if you have ever caught a chip bin full of thin magnesium ribbon, chips and cutting oil on fire.
    You now know the definition of "Major Pucker Factor" Ask me how I know.
    No photos cause I almost got my ass canned!!!!!!!!
    Lesson learned
